MikeB4
Hi all,
I posted this last August and got some email interest, but not enough to close a sale. I am happy to email or talk to list members about it. I thought I'd try here one more time before I advertise to the "outside world:"
1997 Volkswagen Passat TDI Wagon, White, (B4 Chassis)
1.9l TDI Diesel engine (1Z) 5spd. Manual transmission
Color: Candy White
Mileage 237K (132k on ODO + 105k on door sticker)
The Good:
Here are some more pictures (including higher resolution pictures of the rust) and a pdf of my maintenance log:
https://onedrive.live.com/redir?resid=780ABB501B06AE79!3505&authkey=!AEej_1XWE8TmqTc&ithint=folder%2cJPG
Thanks,
Michael Townsend
919-272-0186
mtownsend0@outlook.com
For Sale: 1997 VW Passat TDI Wagon
Indianapolis, IN
$3700
Indianapolis, IN
$3700
Color: Candy White
The Good:
- Extremely rare and hard-to-find VW Passat Wagon TDI! (B4V with 1Z engine and 5 spd.)
- Well-loved & maintained by a detail–oriented engineer who is a member of TDIclub.com.
- Typical B4 issues have already been addressed. (Relay 109, air blend doors taped, radio backlights, injector pump seals, exhaust flex pipe, etc.)
- Relatively new 3M window tinting
- Recaro semi-powered and heated seat for driver
- Keyless entry with 2 key fobs
- I have most maintenance records for the entire time period where I owned the car (last 9 years)
- Relatively new timing belt from a tdi-club list-recommended mechanic (7k miles ago), regular 5k mi. oil changes (always Rotella T synthetic),
- It does have 237k miles on it, so it isn’t new anymore. Smokes on heavy acceleration.
- Engine mounts are stiff when it is cold, so there is higher noise and vibration on cold starts when ambient temperature is below freezing
- It has been rear-ended before I owned the car.
- The right-rear quarter panel is rusting around the wheel arch. I suspect it was a replacement quarter panel.
- The 2 rear tires are approaching end-of-life.
- Add almost 1 qt. oil every 1k miles or so.
- Check-Engine light is triggered on heavy acceleration, especially when it is cold. (The codes are EGR and Timing.) Interesting, since the timing and IQ are set properly.
- The car has only been in Indiana for 2 years, yet there is some rust showing up on the replacement right-rear quarter panel
- The interior upholstery is worn, but serviceable.
- The headliner does not sag, but it does have some stains.
- The shifter boot.
Thanks,
Michael Townsend
919-272-0186
