HightowerExp
Hey all, first post here unfortunately its because im have some issues...
The rear brakes (mainly driver side) on my 2013 Sportwagon TDI, are sticking bad.. mileage has dropped 10 mpg-ish, and they are really emitting quite a bit of heat.. so obviously the brakes are sticking, but I cant find the reason...
I had to get an oil change so i asked the dealer if they could take a look. and they said that it just needs new pads and the caliper sliders Greased. so went to ID parts and ordered the pads with the necessary bolts for the brake change... took the wheel off and everything looks fine, reluctantly Greeced the caliper pins as they looked flawless and put it back together with new pads...
after doing the pads, it seemed to be better getting normal mileage and less heat and now a couple days later its back to sticking. took the center console apart to see if there was a bias in the cables showing a stuicky cable or something and from what i could see they were dead even...
im assuming now its the calipers?
anyone have a similar experience or any helpful info?
Thanks!
Thanks!
