stick with G52 in your tranny - here's why...
BLKGTTDI
Essex
Mk5 VW Golf GT TDI
The G070 is for sure thinner than the G052, but I don't have the data at hand to quantify it and I didn't see it in a quick scan of this thread though it's probably in here somewhere.
Put a liter of each in the freezer overnight and shake them both in the morning.
Thanks for this. Would you happen to know the specific version of G070 you used eg my version of G052 is G052 171 A2. Many thanks.
robnitro
NYC area, NY
2001 Jetta TDI GLS silver
From what I recall, the g052 you mention is the good synthetic original fluid that was in my 2001. It was not notchy when cold or hot.
Then I did redline mt90 - notchy when cold!
Redline MTL - notchy a bit when cold
Pennzoil Synchromesh - great like g052
Then I tried g070 - notchy when hot
dumped that (still have 3 qts of it new)
GM syncromesh friction modified - great stuff
The g070 has been theorized to not be a full synthetic, so it thins out when hot more than the g052 full synth and the syncromesh (which is a tiny bit thicker than oem)
Plano Diesel
Plano, Texas
2009 Jetta TDI Candy White Manual, 2009 Jetta TDI Salsa Red DSG, 2006 Jetta TDI Candy White Manual
Cheers for the info jimbote. Just ordered 3 bottles of Penn SM I'll post up the results after a couple weeks!
I also have a 6 speed manual (02Q). Mine will start to make a humming noise when turning the car after 35-50k on the OEM fluid (G052 171 A2).
What was your experience with the synchromesh?
BLKGTTDI
Essex
Mk5 VW Golf GT TDI
It didnt help my issue at all. I ended up getting a reconditioned gearbox. One of my gear change forks had broken apparently.
DCELL
Sheridan, IN
'01 GOLF 2DR, ‘15 Passat SEL TDI
Perhaps this has been covered, but I've read 30+ pages and my brain hurts.
Car is a 2001 golf with 175,000 miles. I had good luck with the $30/liter dealer supplied g052 from 7 or 8 years ago but I feel like it's time to change it. I ran a quick search on G052171A2 and I came up with a Febi product that's only $10/L + shipping. Indiana goes from blazing hot summers to subzero winters, so I need all weather smoothness. Has anyone tried the Febi product? There is also a Fuchs alternative that's about the same price. Anyone? Thanks
kermeli
Finland
seat exeo 2.0 tdi
Ok ok, probably asked millions of times, but what is the correct oil for my manual seat exeo 2.0tdi, 6-gears. Asked the dealer and he said 170€ for the oils+work, sounds rather expensive to me. I tried to look for the correct oil, but got mixed answers. Any help much appraciated, i really want to change the oils.
This sticker should mention what transmission i have? None of those codes are transmission?? :confused:
TomR
Staffordville CT USA
2011 Jetta Sportwagen 02 Jetta red(gone), 1998 Jetta(gone), 1981 Rabbit dsl(gone)
I just went to VW for gear oil for my 02 and they gave me G60? I see no mention of that in the thread; any ideas if it is correct for my 02J?
Steve.VWguy
Oshawa Ontario Canada
2003 TDI WAGON(not for sale!)
Fluid Capacity
Just did Manual Tranny gear oil change 2003 ALH TDI.
Manual says it takes 2.1 litre , or 2.0 quarts.
fluid warm, let drain for half hour.
took about 1.7 litres not 2.1.
anyone know why this would be??
ps used VW OE gear oil.
robnitro
NYC area, NY
You could have been a bit low or at an angle.
For help in lubricating 5th gear, I used to overfill a bit quickly adding the plug.
With the 5th gear oiling mod it's not needed.
Powder Hound
Steve, you might also note that liters are larger than quarts, so 2.1 liters is 10-15% larger than 2.0 quarts.
A little less than 2 liters is what people usually find. The only way I've found to get 2 liters in is to have the front end high, pour all of it in, then put the plug in before letting down, as robnitro explained.
Another item to note is that a dry, new transaxle will take more fluid than one just drained. This would be due to the oil that sticks to all the surfaces of the internals (not an insignificant amount, by the way) and on the 02J, the 5th gear volume that has no drain.
Cheers,
PH
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
So after posting that I think I read further back that this oil is basically the same thing? Anyway filled the box with it and am pleased to say it's pretty lush, much smoother gears now.
oprn
Coronation Alberta
2002 Jetta
Same here! I just found this site and thread, lots of good info but wondering if it's possible to get a little carried away looking for the "right" lube.
My experience started in '83 when I bought a Ford Escort a when draining the tranny discovered the factory fill was ATF. Did some inquiring, yup that's normal.
At the time I had a VW Rabbit that was extensively modified and putting out around double the stock power. Good test I thought and in went the ATF. What a difference in cold weather! And zero shifting problems in hot weather. No reliability or wear issues found. I actually still have that car.
So Dextron II has been my fill of choice ever since with the only problem encountered is the tendency of it to find weak seals and gaskets and seep a bit.
UhOh
PNW
2003 Golf GLS ([2] 2005 Mercedes E320 CDI)
It's not about getting carried away, it's about getting something that works for you.
For me I decided to research with the notion of getting something that would work w/o having to spend the time and money to be doing a bunch of fluid changes trying to get the best fluid. And it's pretty clear what the top candidates are for 02Js (as well as what NOT to use- I have yet to read anyone that's happy with VAG's G070).
bembasound81
Bucharest, RO
Polo 2006 BNV JCZ
Hi guys,
I actually read most of this thread. I either missed it, or the info was not clearly stated. I have a 2006 Polo TDI BNV JCZ transmission. In 2007-2008, the car had a service action (as they call it), and they replaced the gear oil. Part number used: G052512S0. As I found out, this is an internal part number. We can buy it as G052512A2. At around 100k km, I bought gear oil from the dealer - part number G070726A2. At around 200k km - same part number. I didn't pay any attention to the part number. I thought they will sell me what the car uses...
What do you think I should buy now: G052512A2 or G070726A2. Does anyone know for sure the difference between the two?
I'm thinking about this because I have 2 different noises from the gearbox:
1. something like "hhhhh" when under 0C, at first start in the morning. it stops when the clutch is completely disengaged (everything in the gearbox stops). if it's only half, sound is still there. after 5-10 min of driving, the sound goes away. If over 10C, sound is not present.
2. after wellwarmed up gear box, when over 20C in the air, just before the car comes to a complete stop, so 1-2 km/h, it makes a knocking sound but not continuously - it's like the sound can be heard every 45 degrees of the wheel. car can stop and the noise may or may be not present ( depends on where the wheel or driveshaft stops). if the noise is present, it goes away if trying to engage 3rd or 4th gear without pressing the clutch, or if turning the steering wheel !! it also goes away gradually if pressing the clutch. if the car stops and the noise is not present, I can be heard if turning the steering wheel.
if there was a gearbox issue, why is it affected by the turning of the steering wheel?
the car has no abnormal noises when driven: hard accelerating, hard decelerating, turning hard uphill, breaking hard downhill and turning.
someone gave me the idea of checking the tapered coned bronze ring from the flanged output shaft that comes out of the diff, and when doing so, I will put fresh gearoil in. now, what should I use G052512A2 (the service action oil) or the G070726A2 (the oil that the dealer would sell me now according the VIN) ?
Thanks!
bembasound81
Bucharest, RO
Polo 2006 BNV JCZ
just put in G052512A2. Obvious smoother shifting (25 Celsius outside) cold and warm. I expect the lever to move like through honey in the winter for the first 10-15 min but I won't mind.
When I took out the filling plug (car leveled), about 100-150 ml of oil bursted out, so that confirmed my "suspicion" that I did overfill the gearbox, which is good :).
When refilling, I tilted the car for about 10-15 degrees, and it took about 1.8 - 1.9L of oil before starting to overflow. Then I put the filling plug back in quickly so I guess I overfilled it also this time.
difference between G052512A2 and G070726A2: G052 seems to have a bit darker colour. At room temp, to the naked eye they seem to have the same viscosity.
Chris B
N. central Illinois
2002 Jetta Wagon 5 spd
I've been running the G070 in my '02 for the last 60K at least. I just rolled 300K miles, and she still shifts great. It shifts much better when it is cold (0F or less especially) and all-around I like it better. The only "issue" I notice is when fully warmed up, I will will get a little bit of grind when shifting into reverse if I do it to quickly after depressing the clutch. If I wait an extra second to let the input shaft spin down, it won't.
Chris
New Mickey
The user formerly known as mickey
Utah
2015 Passat
As always I plan to use the Amsoil product. As always, if it causes a problem you all will be the first to know.
-mickey
UhOh
PNW
Chris
Makes sense that that thinner fluid (which the G070 is) will work better in your colder climate. If you haven't tried Pennzoil or the AC Delco fluids I'd say try them as you might find that you have ZERO issues (warm or cold). BTW - I missed the mention of what fluid you'd replaced. Keep in mind that in almost all cases a fresh fluid will always be better than old fluid.
blacksi
Atlanta
Jetta, Passat
My 2001 finally failed at 450k miles 5th gear went out and I never changed the fluid it was original. Every bushing was worn out and sloppy as hell. I put a junk yard 130k tranny in it which feels so much tighter, but I put Mobil 1 fluid in it and it grinds like crazy. I'm going to pick up some OEM stuff this week and give that a try. I'm kicking myself for not just leaving it alone from the junk yard, but if something went wrong I'd be kicking myself too.
3L3M3NT
Sturgeon Bay, WI
04 Jetta GLS TDI, 04 RTDI
For everyone out there looking for less expensive option for the factory G 052 171 A2 02M/02Q transmission fluid, I've finally come across a few good options in my search on what oil to put in my 02M transmission.
I also think I've figured out who makes the factory fluid for VW/Audi and that would be Febi/Bilstein.
Anyway here are the less expensive options I've found:
FCPEURO @ $8.22/L for Febi/Bilstein Oil
Warehouse33 @ $9.77 for Febi/Bilstein Oil
PelicanParts @ $10.75 for Febi/Bilstein Oil
This is for you guys in the UK:
AutoDoc @ 9,92 Pounds for Febi/Bilstein Oil
AutoDoc @ 11,80 Pounds for SWAG Oil
AutoDoc @ 13,61 Pounds for Meyle Oil
Here's another option that people have mention they thought this company may be making the OEM fluid for VW/Audi's 6 speed transmission oil and that would be Fuchs.
https://www.carid.com/fuchs/titan-sintofluid-fe-1-l-sae-75w-80-synthetic-manual-transmission-fluid-mpn-g-052-171-a2.html
And last but not least, I'm going to giving Liqui Moly High Performance Gear Oil (GL4+) SAE 75W-90 a chance and see how it does in my transmission with a Wavetrac differential, even though Wave trac recommends Motul Gear 300 75W-90
Believe it or not, I was able to find the Liqui Moly gear oil for only $10.91 on ECS Tuning. :eek: https://www.ecstuning.com/b-liqui_moly-parts/manual-transmission-differential-fluid-75w90-1-liter/20012~liq/
Hopefully this will help some people out in the future and I believe this will also work for the 5 speed guys out there as well, since I see it lists G070726A2, 0019892603, G060726A2, G052512A2 on site as what this oil will cover.
tikal
Southeast Texas
Thanks for the extensive research in the list below. Another one made in the USA that I am using in my 2004 Passat (manual conversion) with great results:
http://www.bgprod.dk/wp-content/uploads/2016/01/792_SPEC.pdf
3L3M3NT
Sturgeon Bay, WI
I'm glad I could contribute and hopefully it saves others some money in the future by not having to buy OEM fluid from the dealer, since last I checked it was in the $26 range. :eek:
That BG Syncro Shift II looks like a good option as well. Where do you purchase it at?
For reference--->https://www.bgprod.com/catalog/drive-line/bg-syncro-shift-ii/
stevegrass777
uk
audi 80 & passat pd
I’ve used Millers trx synth gl5 and gl4 in a 6 speed Audi a4 b7 and a passat b5 5 speed both manual in the UK.
Both change gear really well and slightly better fuel consumption.
I chose it based on the viscosity in the product sheet was close to what has been tested here.
In the uk on ebay you can get 5 litres for less than £40 so its quite reasonable too.
Great stuff in my opinion.
Cold shifting was mush better than original altho original had about 160,000 miles on it.
http://www.millersoils.co.uk/products/trx-synth-75w80-gl5/604
