GorillaBiscuits13
As the title says, i have no dash lights/clock/odo, but the battery light will stay on.
Battery shows 12.06v so charged it over night. Turned the key same issue.
Can't get the battery out because the 13mm bolt just spins. I've tried a prybar and turning the bolt, but got no where.
I hooked it up to a known good battery, same issue.
Fuses/wiring on top of the battery are all in good order.
I was hearing a whistling sounds when turning the key over yesterday, then I think it was the fans that started to spin up.
Didn't know if there was something quick I could try, other than sending it off to a junk yard.
Thanks!
Thanks!
