Starter wires
Jake Brake
southern IL
2005 Passat GLS tdi wagon
I've had my car apart for a while now. I forgot if both big wires go to the positive lug. I touched the battery cable for a second and big sparks. 3 wires one is the trigger and a lot smaller correct?
caffeine
B.C., Canada
03 Allroad w/04 BHW/02X conversion, 00 ALH Jetta
I believe it's two big wires to the terminal on the starter; one from battery to starter, the other from alternator to starter. A third, smaller wire, goes to the solenoid.
Jake Brake
southern IL
I found my problem I pinched a wire putting the trans in. I had to take it back out to tape up the wire. The trans lined right up and is back in.
