Concat
Hello all.
I was stranded today when I couldn't start my 2005 BEW Jetta.
The starter sounds like it engages ever so slightly for 1 second (light rattle) and then spins freely. I'm not a gearhead, but I'm also not afraid to try and resolve simple issues. I replaced the starter myself a few years back with a rebuild. After some searching on the forums it seems like my issue could be the solenoid, the starter gear teeth or the flywheel teeth.
Before I replace the starter, are there any diagnostics I can do? Is it possible to visually inspect the flywheel with the starter motor removed, for example? Anything else to check?
Much appreciated.
Much appreciated.
