N2TOH
Haha, yea I used to run a German Market Audi ECU in my 96 Passat, The Audi ECU brake signal voltages are reversed compared to the VW setup.
I used to get an "Implausible brake signal error" if I sat with my foot on the brake too long.
Oh NO! Why the Ford Rear? They tend to have really low input pinion gear heights. (Really bad for rear drive shaft angles) I'd opt for reverse cut gears to keep the angles happy.
your running a Dana 300 yes? you should be able install an adapter to get the needed signal for the ECU.
TDIJetta99,
Thanks for the input. I was afraid of that. I'll need to dig into when we get temps above zero, if that ever happens again
I do not have the cruise hooked up yet because I have no VSS to drive it anyway. As soon as the Ford 8.8 rear axle goes in, I'll have a sensor to pull a pulse from. Thanks again everybody. I'll let you know what I find when I dig into it.
