Old thread but hey... anyone thinking of doing this retrofit?... or just me and
@Nuje
New battery > ground cable that includes the battery sensor
PN 5Q0915181J
- This is the J367 Module and has a 2 pin connector, my dealer of choice has this new for $128
- Can be had for under $50 used on eBay, shipping from the EU
- I'll find the connector part number later and edit this post
- Pin 1 - LIN connection to Gateway (J533) Pin 3
- same LIN wire that goes to alternator, pick it up where you want
- Drawing shows available at TML - Left Engine Compartment coupling point, avoids wiring through firewall
- Pin 2 - 12V, engine bay fuse box, spot 18, 5A
Center console switch buttons, different part numbers depending on what your car already has...
5G1927137N control panel with pushbuttons
(Driving MODE / Eco Stop-Start / Blank)
5G1927137P control panel with pushbuttons
(Driving MODE / Eco Stop-Start / ESC OFF)
5G1927137S control panel with pushbuttons
(Blank / Eco Stop-Start / ESC OFF)
5G1927137T control panel with pushbuttons
(Blank / Eco Stop-Start / Blank)
Credit where due... these part numbers were pulled from user
GolfDave's thread over on GolfMk7.
- You can find switch panels on AliExpress, and many come with harnesses/pins which is convenient.
If your car already has buttons here (10 pin connector) you only need to add two wires which go to the BCM
- Switch Panel pin 7 > BCM Plug C pin 51
- Switch Panel pin 4 > BCM Plug C pin 60
If your car has no buttons there you will also need
- Switch Panel pin 1 > Ground
- Switch Panel pin 2 > BCM Plug C pin 62
- This actually for background lighting, and you can tie into the shifter lights (DSG) or the cigarette lighter surround.
- Switch Panel pin 3 > BCM Plug C pin 34
The starter is also a different part number, presumably one with higher duty cycle. The correct start/stop starter does not seem to be available in the US, but is the most expensive part of this endeavor. I will probably do all this without changing the starter, as a test. If it works, I'll then disable start/stop until I replace the starter with the correct unit.
PN 02M911024M -
should be installed currently - Mk7 TDI, PR Code G0K (6-speed manual) and 7L3
(without start/stop)
PN 02M911024S -
the needed starter - Mk7 TDI, PR Code G0K (6-speed manual) and 7L6
(start/stop with regen braking)
- PR 7L6 with "regen braking" apparently has to do with our smart alternators, not to be confused with EV type regen braking
Then of course coding... adding the battery monitor to the gateway install list, BCM coding for the install of the button. Lots of other modules have coding for start/stop enabled so I'll have to go through those... minor concern I think.
