Hi, I searched on this forum and found no thread about this, so I'm starting one. A standalone controller for any engine that uses a VNT turbocharger, vacuum actuated with N75 or with the newer hella PWM/CAN BUS controller.I'm not sure how to put this, but should be sth like this: default map for the controller to be a map working with TPS/RPM , if TPS > RPM (at least 6% more, to avoid vanes movment when cruising) then vanes should be closed up to a boost limit, else TPS<=RPM , vanes open down to a set up EMP value for good fuel economy while cruising,and quick enough response when accelerating.And of course an EGT failsafe input that overwrites the rest and open vanes if too high. I'm not a programmer, I just came up with the idea ,what do u think guys?
