she_loves_the_D
Hi. I am an avid tdi driver/enthusiast.
I ended up picking up a free ALH motor. no ecu. and will be hopefully putting in something cool RWD and pre 75 car or truck. Rusted cylinder. will be my first rebuild.
Anyways i have been looking into how to do the wiring for a non vw car. After some research it looks pretty straight forward. ECU plus any engine sensors. OBD2 plug and accelerator sensor/wire.
So that will be 75 for ecu 150-200 for the harness. Then 500 for kerma tune and 150 for immobilizer delete.
At that rate i will be entering into the standalone price range. The only thing is i cant find any.
I know the diesel works a little different then regular engines with spark plugs. But it should be much easier as there are less components.
I found a really cool open source stand alone ecu called speeduino. I would add a link but im not sure if that is allowed.
It is arduino based. and uses the same tuning software as many other ecus.
I really wish i knew more about coding or all technical aspects of the electronics on the car.
I just wanted to open up the conversation about getting one made for us tdi folk. Maybe there are some tech savvy people on here.
If they can make it for gas then it could definitely be made on an engine that can technically run without electronics.
I guess to start i would ask.
What all channels/sensors would be needed in comparison to a normal gas engine?
hope this draws some attention. Feel free to link it in other sections of this forum if it would do better there.
