VATechTDI
Yesterday was about 0 degrees F in the morning. I had about 3 gal of fuel in the tank. I had added white-bottle Powerservice the night before, and I added enough for a full tank. Started ok, got to work no problem. Temps did not climb above 15F during the day. I filled the tank (topped off, vented) with diesel during the day at work which is about 55 mi from home.
On the way home, made it about 20 miles, then the engine died going uphill without warning. Power started to fade (heard no unusual sounds or noises), then it stalled just as I was getting it off the road. It was 10-15F, and my first thought was maybe it had gelled.
Waited an hour for a tow back to the house. During that time I tried a couple of times to start and it turned over but didn't catch. While waiting I had a good Samaritan watch the fuel window for me while I tried to crank and told him to look for any bubbles moving-- he saw none.
This morning I added some more white-bottle Powerservice to the tank and tried to start it. Battery was totally dead. It had been on it's way out anyway and having a hard time with cold mornings so I went and bought a replacement.
Replaced battery and cleaned the grounds under the battery tray while I was at it.
Engine now turns over normally now but will not fire. I do see a few bubbles moving through the fuel tube when the engine it turned over.
VAG scan returns:
Address 01: Engine Labels: 038-906-012-CP.LBL
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G500SG 2839
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
17656 - Start of Injection Timing Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
I drained a tiny bit of water from the fuel filter but not much at all. The belts appear ok, the timing belt is about 5k miles from due for replacement but appears to still be in good shape (teeth not badly rounded or anything). I realize I have no way to tell visually if it's skipped a tooth.
I don't have a helper here to try cracking injector lines to check for fuel being pumped.
I have checked for stuck ASV and it's open.
When cranking the engine, after about 10 sec cranking the oil pressure light flashes and beeps. Don't know if that's normal.
If there's anything else I should try please advise. Thanks very much
Tim
VAG scan returns:
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
Tim
