stage 2 malone or ? offroad use
single94
usa
2012 passat tdi
I was contemplating doing a stage 2 with delete for offroad use only, anyone else done this yet that can pm me, i recently found my plastic adblue sensor cracked, so im looking to replace it, possibly use 3m plastic adhesive 1099 to fix it. If anyone has any experience using this glue or another to repair plastic please let me know. prefer to swap out rather than glue it if possible, but may do tune as well. Looking for some insight or possibly someones un needed or broken sensor. thanks in advance
767wrench
Ohio
1981 Rabbit Pickup
Im not sure of which sensor you're referring to. The system has a ton of sensors lol! Do you have any fault codes stored from it? I had the delete done on mine. It costs alot and is alot of work but it can be done. If you plan on keeping the car a long time i say its definitely worthwhile. theres a lot that can go wrong with the system and when it happens it needs fixed immediately to prevent damage and may go into lockout preventing you from starting the vehicle until fixed depending on the problem. The extra power with the stage 2 is nice. your egt will be drastically reduced with the delete and I believe it solves the turbo failure problems as well by eliminating the warm up and regens. Exhaust sounds nice with a muffler delete as well it isnt too loud. similar to a stock neon srt 4 in my opinion.
