There was a local ALH TDI that previously had its cat & muffler removed, and then a Stage 0 setup was installed. It was not long before the muffler was re-installed. I definitely recommend against running a straight pipe without a turboI just realized the cat and mufflers would need to be returned to any car without them. No turbo to muffle the sound with Stage 0.![]()
A switchable-on-the-fly tune is in development and engine braking via VNT is definitely possible. Another possible solution is to use the exhaust flap from a 2009-2011 TDI (a number of owners are throwing them out in favour of a straight pipe) and wire it to the brake pedal. Someone here made an electronic VNT actuator work with EDC15 (ALH ecu etc.) so it's feasible. The exhaust flap may be more effective than a closed VNT.Mark, since you are proposing all sort of wacky ECU tune ideas lately, let me suggest another one:
Additional engine braking through turbo boost at zero throttle, for the people who frequently tow with their TDIs. I sort of accidentally have this mod right now (sticky VNT gets hung up on boost sometimes) and coasting distance is reduced noticeably with only 2-4 lbs of boost at zero throttle. I would imagine that 15 lbs of boost could help slow the car even more. Would have to be switch selectable somehow though.
No offense takenBTW: No disrespect intended Mark. Just preemptively poking fun at anyone who might try and build an 'all-motor' TDI.
x2... I have fond memories of modifying my hopelessly under-powered Ninja 250. No matter what you did, that motor was never going to put out much more hp than a small riding mower. Sometimes, it's just fun to tinker!We don't need a powerful base motor to enjoy modding them.
It would be interesting to see the specs of a PD SDI cam. Colt Cams does regrinds for 1.6L NA engines. I don't remember what the general opinion on these cams were, or if there's even a dyno. bhtooefr might know as I haven't checked the popular IDI forum lately.VW must already make a NA diesel cam
In theory, yes. In practice we'll see. I'll need to take a 'SDI' from sea level up to one of our mountains (3000+ ft) quickly and do a smoke opacity test.Two more questions.. I've had diesels that had to be modified to work properly at altitude. Will the NA diesel sill function pretty well at altitude?
My 73 bay window bus did ok with less than seventy hp. It weighed a smidge over 2 tons. I actually had to reign it in to help keep from overheating the aircooled heads.
Not to mention potential engine longevity increase as well. This is simply an option for those who want it or need it
- Industrial applications.
- Simpler engine swaps.
- A potentially lower cost alternative to replacing the turbo.
Yes this particular car is not a low budget setup. I cannot reveal details yet, as per the client's wish. A low budget setup will involve stock VW NA components, which can be found easily & cheaply. For most people Stage 0 will be used for simple swaps, longevity, or with low cost parts.Not bashing the stage 0 idea at all.. but you could get a VNT15 in good condition for less than the cost of that header, haha. What upgrades are ahead? What is the motivation for this car's owner? very curious.
Hi Marc,b1gmoose: I answered most of your questions in e-mail. The MAP sensor can be deleted. If you want to rotate the intake manifold inlet 180 degrees, then yes you can chop & weld it. Or use a AHU TDI intake manifold, or PD130 intake manifold, or even a SDI intake setup.
Actually the shift forks on the 02M are problematic, they tend to break frequently.The 02M isn't really known for any big problems. (It's a 6-speed manual, as used in Mk4 cars, 02Q being the Mk5 version.)
That is an oxymoron.. An all motor Turbo Direct Injected Diesel?'all-motor' TDI.
I've always wanted to play around an hang an eaton m90 off of a tdi. I think it would be fun for an off road toy in a samiDo I see a Super charger in its near Future?
That would be so much fun, BAM! power right now.Do I see a Super charger in its near Future?
You are correct, the pictures that Mark posted are from a project that we,JSP and Malone Tuning are involve with.JSP have been involve in several supercharged project that have produced some amazing results both on the track and on the road. So it was time to take these results and adopt them to what we know well, VW Diesels.Do I see a Super charger in its near Future?
JSP mentioned the Eaton model number but I forgot. The main focus is low-RPM response/torque so it probably won't be an enormous supercharger.If you don't want to say till the project is done I understand, but I'd be interested to know which supercharger you plan on using.
