i got an email from a vendor about these and wondering if anyone has used one and if its actually worth it. just curious if its worth the like 300 bucks
Yeah, which you can do by pushing down on the GO pedal faster. All it does is ask for more throttle than the driver does, up to a point, and then levels back off at full throttle.
This device does actually work. You can push down on the "go faster" peddle as quick and as much as you like but it takes a set time for a drive by wire system to respond unlike the old mechanical set up used in cars. With this device it speeds up the responce time from when you push the peddle to when the engine responds. This can be done in a map as well if the tuner knows what he is doing.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
