Spring under Golf seat
Edtom
Beverley UK
Golf Mk 4 130
Just found a large spring loose under the passenger seat, checked the driver seat and it appears to fix underneath along the side next to the door, appears to have something to do with the seat height adjustment. The attachment for the far end is out of sight so I cant easily fix it back in position. Everything seems to work OK without it. Question, anyone know exactly what this is for, does it really need to be in place and is there an easy way to reinsert/attach without taking the seat out? Thanks Ed
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Yep, common for those to show up. I have a collection of them hanging in the garage. Seats seem to work OK w/o, so never bothered to replace them, or even figure out exactly where they go or what they do.
OlyTDI
Olympia, WA
'04 Golf
It's funny when it happens, though. I remember thinking a spring that size and that beefy must serve a critical function. Was very entertained to find-out they're not essential.
Seatman
Scotland
2007 Seat Alhambra 2L tdi
Well I'm anal and replaced the dam thing lol I think there's plastic end parts that break and that causes the thing to fall out.
I've figured out where it comes from, it's connected to the height adjustment. I think it's just to take the strain off the lever really and the seat works fine without it but I'm anal so it had to be fixed lol
It hooks onto a lever at the outer edge of the seat underneath
And the other end on here
Anyway you want to hook the spring onto the lever first
Then use a screw driver to lever the other end on. You kind of put the screw driver through the end of the spring and the tip against the hook then push like a mofo. It's seriously tight but it does work
And should look like this when finished
Another little thing out the way, still ore of them to come I'm sure lol
pedroYUL
MI, USA
My pass side just showed up last weekend. I intended to ask but forgot about it since everything moved just right without it.
Seatman you'da man! I will fix it following your directions. I did find the little plastic thingy that broke
PDJetta
Northern Virginia
I think everyone one of us have at least one of those.
Not me, I chucked both of mine in the trash. :D One of them let loose when my wife and I were driving (her side, passenger seat) and it made a racket like a shot going off. She freaked out and I calmly said, "It finally let loose".
And I was with my mother in her '00 Jetta TDI (I was driving it) and as I was just starting to wrench on the seat height adjuster to lower it, at that time wondered when her seat spring was going to go and all of a sudden, Bam! it let loose. It took several minutes to explain to her that spring was not needed..."But if it was installed, it must be needed." Me, "No its not". Her, "but why", Me, "It just isn't". Well a couple of weeks later she said, "you know what, that spring is not needed". She thought she would need the assist it provided because she is 76 years old (and drives a 5-speed TDI).
--Nate
Edtom
Beverley UK
Golf Mk 4 130
Brilliant responses, thanks guys, its put my mind at rest on this, logically I couldn't see anything it was doing but was also thinking surely there must be a reason for a great big spring!! Its not going back in unless one day I have the seat out for another reason and i can easily fiddle about with it. All Best Ed
Volk14
Asheville, NC
05 Passat wagon TDI, 99 Beetle ALH
I've thrown away a few of these. Both of my B5.5 Passat's don't have them and never really cared to find out where they're going since everything works normal and makes the car even lighter (every oz. count) :D
At least I know where they're supposed to go now :)
oEo
Lancaster | PA
'04 Golf TDi PD ::Indigo Blue::
Funny, all 3 MK4's Golf's that I've owned has had this spring fall off the drivers seat! Never put it back on.
Steve-o
Saint Paul, Minnesota, USA
2003 Jetta Wagon
Unbelievable! Just this week I found in the footwell the spring they issued my passenger seat and, yeah, I figured it was important. Only to find out it apparently is the appendix of the A4 body... Into the metal recycling with it.
I love this site.
tongsli
Baltimore, MD
I have power seats so no spring. But one did fall out in my wife's car and I've never put it back. Not even sure where it is.
Haven't noticed it's absence.
tnothwehr
minnesota
1.8T wagon
Fix for MK4 jetta seat springs
I figured out a way to fix the seat springs. I just got registered on the forum so I'll post the pics tonight when I get home from work.
Just a forwarning so you don't get stuck with the airbag light on like I did; disconnect the battery before you remove the seats. My regular mechanic is going to reset it for me today for $0. I think the dealer will charge for this.
Sideoiler
Rancho Cordova, California
2003 Jetta GLS TDI Wagon, 5-spd, Indigo Blue
I can't seem to post pictures so here is a link to a google doc that explains, with pictures, how to fix the height adjustment springs on the seat of a MK4 Jetta.
https://docs.google.com/document/d/1T1QUnVxp-5V1MiXe2526P0lagrV8yedYiBjsnklniPI/edit?usp=sharing
A nice fix indeed.
I did basically the same thing a few years back to both my front seats. I'm not sure what the VW engineers were thinking when they decided to use that weak, stretchy, and soft metal insert as a hook mount...:confused:
That Guy
Edmonton, Alberta, Canada
2001 MKiv Golf TDI
Why not just hook the spring through the hole that the broken bit came from?
I'm swapping my velour seat covers for leather which requires removing the seats to do the reupholstering. I've got the passenger front seat out now, I'm still deciding how best to handle the heated seat part so it'll be out for a bit. (I drove to work today without the passenger seat. Certainly feels more open.)
But ya, I discovered that that spring is not connected, so I will be attempting to fix it.
If hooking the spring in the hole works I'll do that. If it causes some problem I'll probably stick a bolt in there as tnothwehr did.
That Guy
2001 MKiv Golf TDI
So I poked around with this a bit last night and discovered that putting the spring through the hole that the bolt was in won't work. There's not enough room to maneuver the hook through the hole.
I could hook it on the area with the sprocket teeth. And that actually seemed to work okay....after lubing it up with some Marine Grade Anti-seize grease. But, that didn't feel like a proper fix.
So next on the to-do list is trying that bolt fix above.
I might put some LockTight on that nut to prevent it from wiggling off over time.
And that spring... Holly crap is that thing strong. It took some real strength to get it up and on when I was messing with it. Next time I'll try that block of wood idea for leverage instead of strong-arming it.
That Guy
2001 MKiv Golf TDI
Both seats are done. The spring was broken off on both seats.
I found that I had a set of nut and bolts that were exactly the right length, and just a bit smaller that the existing hole. So I didn't tap the hole. Other than that it was pretty much the same as what tnothwehr did.
The new nut and bolts are steel and should last. And the nut will never come off as there is no room to.
Raising and lowering the seats is much easier now. Plus it feels good to have the springs in use the way they were meant to be.
