79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 Jetta GLS 5 Speed
Tuesday after work I went into town to get some groceries. My speedometer and everything was working just fine when I went in the store. When I left I noticed that my speedometer was not working. At first I was not too worried about it as I figured I would fix it when I got home. When I hit the road out of town I tried to activate the cruise control and found that did not work either. Then noticed my fuel gauge was acting weird. I decided to pull over and check my fuses and found the 10 amp cluster fuse was blown. I replaced it when I got home and drove around the farm a little and all seemed good. When I went to leave in the morning my car did not want to start, acted like it was not getting fuel. The battery was getting weak so I hooked up jumper cables. It still cranked over for probably another 30 seconds before finally starting. After leaving I noticed the speedometer was not working again. Checked the fuse again and it is blown.
Where do I need to start looking to find the issue? I am off work for the next 12 days, but I cannot put it in the shop as we have some rigs already in there torn apart and it is going to start getting cold out. I don’t want to start guessing at what I need to do if I can get some pointers first. So any help would be greatly appreciated.
