Looking for contact info for buzzken. Can anyone pm me his number pls, I tried pm but looks like he hasn't been on here in awhile
That wouldn't turn me off. If a seal isn't leaking I let it be. The chances of a new seal leaking are higher than those of an old seal starting to leak in my experience. Our sedan will be due for it's 4th timing belt soon, it still has both original seals and no leaks.I just called the local shop in Sarniaa with a lot of Volkswagens up front, willy and karl's, even at 300,000 km they weren't going to change the camshaft and crankshaft seal, I'm a bit turned off
I don't know why I haven't seen anyone mention Strictly European Motors (SEM) here, but I took my 2013 golf tdi to get the timing belt and water pump replaced, and they did the serpentine belt and replaced one of the worn tensioner rollers too. Very good prices, honest and professional. I know they have a very good rep in the gasser audi/vw world, hence why I elected to give them a call and settled on going there. Highly recommended if you're in the greater Toronto area looking for a place to go to
top gear import parts in london is fantastic he did my timing belt, dsg, rear brakes, cv boot on my 2014 tdi golf wagon and he was great.Does anyone still recommend AutoBahn in London? I have a head gasket that needs to be done and I'm not certain I want to tackle it myself. I'm also considering Dewey's, anyone had TDI service there? I know he does trucks mostly.
V dub performance in Etobicoke. That’s all he works on.Newbie to the site and still catching up/going through all the threads, but need a repair now, lol.
Any recommendations for a delete shop/tune shop, Toronto gta within 2 hrs?
Thanks in advance.
Cheers thanks. Car had the updates, only 120k, but egr is coding :/V dub performance in Etobicoke. That’s all he works on.
Any further advise on Willies? I'm looking for VW specialist in this area. ThanksI second this Request.
anyone used Willies on #12 north of Brooklin?
Did you use AM24 in Oshawa? I'm thinking of taking my car there for an engine swap. Please advise.Looking to get my timing belt done close to Oshawa Owasco quoted me at $1600any recommendations?
Did you come across anyone?Recommendations for an independent mechanic near Markham rd and Hwy 7.
I'm looking for someone reputable that I can bring my own parts to.
Thank you.
hi guys, I moved from bc to scarborough toronto area (kingston rd) do you guys know any guru guy working on vw on the side ?
thanks a lot
Also, if they didn't SEE a leak, are they saying that it HELD pressure? If so, how are they explaining the vanishing coolant? Sounds like you need a different shop doing the diagnostic.they claim they did a pressure test and didn't see anything that would explain the loss of coolant
I assume you are out of dieselgate warranty?
correct it held pressureAlso, if they didn't SEE a leak, are they saying that it HELD pressure? If so, how are they explaining the vanishing coolant? Sounds like you need a different shop doing the diagnostic.
