Sound Off on Current Diesel Price
rotarykid
Piedmont of N.C. & the plains of Colorado
1997 Passat TDI White,99.5 Blue Jetta TDI
In the Denver area as of this morning D2 is running the cheapest was ~$4.20-4.35 for B-02 to B-10% which is the amount of Bio Diesel minimum requirement in all D2 sold across Colorado...
I also add 2-3 US OZs of acetone to each fill, which helps keep any moisture dissolved in the fuel, keeping gelling away before the winter switch to treated fuel in a few weeks out here...
Also I change my my DOT4 brake fluid in all my vehicle reservoirs sucking out the old with a large syringes every 3-4 months throwing the old brake fluid in my Jetta & Passat TDI's tanks, this helps keep all of the seals soft and leak free. Ends up being some of this in my fuel most of the time since I am pretty much changing one of my four vehicles brake fluid every few weeks...
Don't try any of these things if you have a TDI-CR car, the rotary type injection pump (VE pump) engines have no problems chugging my fuel mixes. The TDI-PD engines are a little more fuel mix sensitive, but they can run on this mix....
kjclow
Charlotte, NC
Just don't do any of those things to the CR diesels! Don't think the HPFP or the DPF will like any of it.
El Dobro
NJ
2017 Bolt EV Premier, 2023 Bolt EUV Premier
$3.61 for RUG and $4.79 for diesel at the local Speedway.
TornadoRed
2003 Jetta TDI wagon, silver; 2003 Jetta TDI wagon, indigo blue; 2003 Golf GL 5-spd, red (PARTED); 2003 Golf GLS 5-spd, indigo blue (SOLD); 2003 Jetta TDI wagon, Candy White (SOLD)
It is a normal seasonal pattern for diesel prices to gain relative to gasoline at this time of year. All of the winter-blend gasoline that has been stored since April has now come back on the market.
JELLOWSUBMARINE
yes
$6.50ish here in Central Valley Modesto area.
We can go on and on about seasonal patterns and whatever but the controlling factor is truly deeper than that. The prices will/are being falsely held down by selling off and by using up our oil reserves...
UNTIL the election... MARK my works the $ will go sky high after the election.
Ask yourself this. Why is Ca. sooo much higher than anywhere I know? Because theyve already got this state hijacked... Why is red state like Texas so low? (yes the oil production still part of the formula). But the PRE election contributing pressures, what ever they are, help sway the "on the fence" voter to go blue. Texas beware you aren't safe and are in the cross+hairs for sure. They're so hungry for this state it makes their tofu' burger look like beef. Half of my heritage is in Texas so Ive been watching this intensely FWIW
kjclow
Charlotte, NC
Paid $4.52 over the weekend in Lake Wylie, SC. managed to stay just under $100 for the truck.
Mozambiquer
Versailles Missouri
I paid $4.76 yesterday. The cheapest I saw was 4.69, but the station with 4.76 had an offer on upside for $.24 back and gas buddy for $.14 back and it was a shell station, which I have rewards at which gives me $.03 back, so it ended up being a lot less.
TDeanI
Bremerton WA
'97 Passat TDI Wagon w/ 286K mi.
I saw $4.99 for a gallon of diesel and $5.07 for unleaded Sunday. So diesel is cheaper than unleaded for the first time in awhile here.
CleverUserName
NorCal
Here in Sacramento CA.
Costco B5 is $5.25/gal
Woodland Fuel Stop Diesel #2 $5.65/gal
Mobil synergy diesel efficient $6.10-$6.99/gal
kjclow
Charlotte, NC
diesel has dropped to $4.29 in SC but still just over a dollar higher than rug.
JELLOWSUBMARINE
yes
CleverUserName
NorCal
$6.49 now...
If you’re ever near Daly City there is an Exxon station that has cheap premium diesel. Exxon and Mobil are the only places to get Synergy Diesel Efficient fuel. Current price is $5.99/gal
Exxon
1216 Hillside Blvd
Daly City, CA
aaronjbeetle
Seattle, WA
2014 Beetle Manual
Exxon
1216 Hillside Blvd
Daly City, CA
Ohhh this is good to know! I'm in the Inner Richmond and pop down south quite a bit.
TornadoRed
ULSD futures price on the NYMEX price is up 96 cents/gallon since the beginning of last week. I'm not surprised, really. Just need to make sure all your tanks are full before the really high prices hit your local stations.
El Dobro
NJ
$3.59 for RUG and $4.99 for diesel at the local Speedway.
Cuzoe
Los Angeles
MK7 Golf S
Just paid $6.79/gal here in the SFV, Los Angeles area. Would have been $7.09 without grocery points.
Could probably drive around and find it somewhere in the middle of those prices without the need for points. But I don't drive enough to make a search worth it. This was my first fill up since late August.
JELLOWSUBMARINE
yes
My crystal ball says: prices will go up until just before the eleection then drop enough to make most feel some sort of relief.
crashtested
Nelson, BC
2016 Q5 TDI Technik, 2014 GSW CL 6MT (RIP), 2004 Jetta GLS 5MT (sold), 2010 GSW HL 6MT (buy back)
Saw it for $2.279/L in Southeast BC last night :oops: I need to fill up but not at that price.
Works out to $6.77/gal.
