crisp006
Hi guys,
I was working on swapping the injectors on my car (still a work in progress) and after following DBWs advice to clean the injector port bores with a 12 gauge shotgun brush (the one I have is phosphor bronze) I noticed that the bore on the #3 injector is chipped in 3 places along the edge of the bore... each chip being obviously a small fraction of an inch in size. I will attach photos to this thread.
Now, I’m not really sure how that happened. I’m thinking maybe the spiral tip of the shotgun brush clipped the edge of the bore when the drill was spinning and caused it. Aluminum is soft but that still seems like a long shot. Perhaps they were already damaged and I didn’t notice? I only noticed this for the fight time when using a bright flashlight to peer inside.
Two questions:
Because the chips are small and don’t span the full width of the bore between the inside diameter and outside diameter, will this cause an issue with sealing? I’m really hoping I don’t have to get the bores cut/sanded.
If those small chips of aluminum fell into the combustion chamber, could that damage the engine? I have not started the engine but *may* have hand cranked it depending on when/if the pieces fell in, as I recently did the timing belt (car is in the final stages of an engine swap). and if so, how would I even get them out?
In advance I want to say I appreciate any help or advice you guys can render.
Two questions:
