SOLD - FS - 2000 Jetta GL TDI 5-speed
sqdude
Eugene, Oregon
2000 Jetta TDI
SOLD AS OF 8/3/24
Well…the time has come to sell my beloved TDI…Life circumstances have changed and I need something bigger for my wife, 2 older kids and a dog.
I am the 2nd owner. I’ve had this car since 2006 and it’s been the best car I’ve ever had. Following the advice on this forum, I’ve driven it “properly” with regular revving above 3,000 RPM and the occasional Italian tune (when properly warmed up).
The car has lived its whole life in the Eugene, OR area; no ocean salt and no winter road salt, mild climate. It lived in a garage from 2009 to 2022, and outside the rest of the time.
I have absolutely loved the TDI community over the years and my preference is this car goes to one of you fine people who will cherish it. Please don’t buy it for your idiot teenager to crash!
Pictures: https://forums.tdiclub.com/index.php?media/img_3266-jpg.160195/full
Specs:
Year: 2000
Model: Jetta TDI Sedan GL ALH, MK4
Odometer: 175,xxx
Color: Tornado Red
VIN:
Transmission: 5-speed
Steel wheels + Hubcaps
I bought the car with 29,000 miles on it. Lately I’ve only averaged about 7,000 mi per year
Price: $3,500 OBO
Mods/Add-ons:
Panzer skidplate
Frostheater
5-brake light mod
Rubber floor mats and rubber trunk cover
Shocks/Struts: Bilstein TCs front and rear
Ventectomy
Aux cable plugged into the original radio in the CD port (the car didn’t come with a CD player)
Engine cover cups/plugs for quick removal of engine cover
Maintenance:
Oil changes done about every 7,000 miles using Pento High full synthetic (see photo)
Major repairs were done by TDI Guru Oldpoopie (Justin) in Portland OR, with parts from Cascade German
Last Timing Belt: 6/10/2012, 100k model, regular inspections and timing checks since then
All maintenance is logged in a spreadsheet (see screenshots). I can email this to you if you want. I’ve logged absolutely everything from windshield wipers to timing belts.
Recent work in the last 3 years:
  • Oil/filter 5/27/24
  • Windshield wipers 10/28/23
  • Injection pump seals and quantity adjuster 10/26/23
  • Cabin filter 8/6/23
  • Front Brakes 8/6/23
  • Rear Brakes 8/6/23
  • Brake Fluid 8/6/23
  • Timing Check 8/6/23
  • New Windshield 2/14/23
  • Fuel Filter 1/28/23
  • Full Diesel Purge session (about 1 bottle burned) 1/28/23
  • Lower Control Arm Bushings (front rears) 10/11/22
  • Coolant Temp Sensor o-ring 6/12/22
  • Hard Coolant Pipe o-ring 6/12/22
  • Coolant Flange o-ring 6/12/22
  • New Vacuum Pump 6/12/22
  • New Coolant Reservoir 6/12/22
  • Oil/filter change 3/27/22
  • New Vacuum Lines 10/23/21
  • Brake Fluid 10/23/21
  • Thermostat Housing 10/23/21
  • Coolant Flush 10/23/21
  • Fuel Filter 9/5/21
  • Air Filter 8/22/21
Fuel:
  • Nearly every tank was B20 or higher, and the last couple years have been 100% renewable diesel. All fuel came from ASTM commercial sources with regular turnover and no quality issues/claims.
  • Occasional Diesel Purge added to tanks
What’s Not-So-Good:
  • There’s a new coolant leak as of a few weeks ago. Not sure where it’s coming from. It is intermittent and only happens after shutting down and also after it’s sat for a couple days. It’s a leak for sure, with spots on the pavement when it happens.
  • For a few years the clutch has had a slight stutter when the engine is super cold or the car has sat for a few days. It’s only in 1st gear when you first get going. When the engine is warm, or when shifting in other gears it’s not there. Overall engagement of the clutch and performance is normal. I normally use the Frostheater every day, regardless of time of year, so I rarely notice the clutch shudder.
  • The glovebox thing is broken that slowly lowers it down. The hinges are fine and it stays closed and it locks properly.
  • Small Oil leak at EGR valve
  • A couple years ago some jackass backed into the rear driver’s wheel well and dented it (see pics). I didn’t get around to fixing it.
  • The driver’s side mirror was replaced in 2013 but I didn’t paint it. It’s totally functional, just doesn’t look super hot.
  • The headliner started sagging a while back and I stapled it up.
  • Some small seat tears in the cloth on driver’s side and rear driver’s side
  • Some scratches on the rear seat from one time my cat got inside while the car was in the garage with the windows down
  • Clear coat is a little haggard in a couple spots.
  • Overall the car looks fabulous from 20+ feet away. Up close there are small scratches and tiny dimples and stuff you’d expect from 24 years on the road.
Also Included:
  • Official VW “Winter Front” faux leather cover for the front vents to speed-up warm-up in winter
  • Yakima roof rack bars/system if you’re interested
  • Rear Thule bike rack, straps onto the trunk
  • Pela oil extractor
  • ~3L of unused oil
  • 5 gallon plastic yellow diesel fuel can
  • Oil filter cap wrench adapter
  • 2 unused fuel filters
  • ~½ jug of VW red coolant
  • Original VW owner’s manual and radio code
Thanks everyone!
ITSPREZ
Batesville, IN
2001 Jetta TDI 5spd
Excellent example of how a for sale posting should look (great looking VW as well)!
I appreciate the love that has went into this A4 and really appreciate the details in your posting.
I do have a question of verification on the maintenance work done as it seems odd so I just want to verify. Is the 2012 date correct for the last TB change?
Only asking because even for 100k belt 12 years is a long time so I am assuming there is a typo in the posting and it is not 2012.
sqdude
Eugene, Oregon
2000 Jetta TDI
Excellent example of how a for sale posting should look (great looking car VW as well)!
Thanks! I tried to follow the instructions.
Yep, the timing belt was indeed done in 2012. There have been several inspections and timing checks since then. It was on the list to replace this fall until I decided to make the car change. And I dropped the price a bit to reflect the need.
sqdude
Eugene, Oregon
2000 Jetta TDI
I just realized I forgot to include screenshots of the maintenance spreadsheet, I've uploaded them to the photo album.
Abby
NJ
2006 Jetta TDI
I hope it sells quickly. If it doesn't I'd be interested come Sept. 2024.
