Diesl
- Joined
- Dec 3, 2012
- Location
- Chicago
- TDI
- '78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
Due to retirement and the pandemic, I'm not driving much anymore. I already used up one battery (which was already eight years old at that point) early last year, by letting it sit without disconnecting from the car. After sitting completely discharged for the second time, it was dead.
To keep the new battery alive, I attached a solar charger. Initially I used a 25W solar panel behind the windshield, but the battery state of charge was still degrading. I switched to a 100W peak power panel, which is about as large as will fit behind the windshield of a JSW, but after a few weeks with the solar charge controller connected to the battery 24/7, the battery would again be at 12.2V, which is about half charged (12.8V = 100%, ~11.6V = 0%). I could probably make this work by connecting the controller only when the sun is shining, but that seems like a lot of work. A 100W panel should be plenty big, so something odd was going on (in addition to the solar charge controller parasitic current draw).
Today I finally measured the charge current with the panel behind the windshield, and directly exposed to the sun: it was more than a factor two difference in current! So I moved the panel to the roof. It turns out it fits almost perfectly between the JSW roof rails. The charge controller is zip tied to the left rear passenger 'panic handle', so that I can check the readings from the outside.
I'm using a 25A 'uxcell' solar charge controller https://www.amazon.com/gp/product/B071VVRWCD for about $20, and an
' HQST 100 Watt 12 Volt Monocrystalline Solar Panel' https://www.amazon.com/gp/product/B018BMGTTO, currently $80.
panel dimensions: https://images-na.ssl-images-amazon.com/images/I/51ERFNvRykL._AC_SL1000_.jpg
