Software Coding for Navi/Radio
tongsli
Baltimore, MD
RADIO Software Coding
Format for software coding : 5 digits ABCDE
A: country (europe/non-europe)
B: vehicle (Golf, Bora, Passat)
C: number of channels (2 or 4)
D: sound correction (DSP, Monsoon, none)
E: sum of options (active aerial, CD changer, FIS)
0 Europe
1 Golf, Use 1 the same as a Golf, for Jetta that should work OK
4 4 Channels (four speakers)
2 Sound Correction
1=no correction
2=DSP
3=Not sure?
7 This is the sum of options as follows
Active aerial =1 (standard on all VW's)
CD Boot changer =2
FIS display =4
Navigation Unit software coding
00001 = No TCM/No Telephone
00002 = With TCM/No Telephone
tongsli
Baltimore, MD
BRIAN
Code your Radios to the following
01437
CHRIS and I
01427 since we have DSP
tongsli
Baltimore, MD
Oh my goodness. Chris!!! Have you coded your Radio yet? The sound just gets better and better.
Isn't it amazing when you code things properly??
Now I am impressed with the DSP. I would really like to hear the Monsoon with NAVI coded properly.
Lito
tongsli
Baltimore, MD
I get no DTC's. The only thing I can think of is your car started out with Monsoon. Mine didn't.
L
larrs
Ardsley NY USA
RADIO
DSP
Use 1 the same as a Golf, that should work OK
so
5 digits 00000
0 Europe
1 Golf
4 4 Channels (for speakers)
2 Sound Correction
1=no correction (use for DSP)
2=monsoon 2-door
3=monsoon 4-door
CD Boot changer =2
FIS display =4
Navigation
My car is a Passat sedan with Monsoon. Initial coding on the radio was 00400 and 00002 on the Navigation.
I could not code the radio to 01433, which looks like what I need. It just wouldn't take that code. I tried 01423, which it took, but that seems to be for DSP -- at least that's what displayed on the screen when I tried the radio -- and it sounded wrong. Tried 01413 and it took that. So I'll drive it that way today and see how it sounds.
I also changed the navigation to 00001, since I don't yet have the TCM box.
Thanks!
mackwood
california
2003 jetta grey
one question, i installed the mfd and have coded nothing. i don't have monsoon or dsp. should i change anything or just leave it be due to no options. i'm just wondering what this coding is for?? thanks, Mack
tongsli
Baltimore, MD
What is the software coding for your radio now?
mackwood
california
2003 jetta grey
Ok, got a vag-com and tried to log into the radio but it wouldn't go. i was trying 56. i yet to get the full version vag-com. do you need it for this?? just says couldn't find controller.
danix
Raleigh, NC
None now. Former: 2011 335d, 2010 Jetta TDI, 2003 Jetta TDI Wagon. 99.5 Jetta TDI, 98 NB TDI, 3 different black 96 Passat TDI wagons.
Make sure you have the K wire installed to the unit, I had to add one on mine.
danix
Raleigh, NC
While I'm here, should I leave my coding as 00407, or change it to 01417 as per the post?
I wonder what the model codes in the second field are - could 0 be the Passat?
danix
Raleigh, NC
Nope, stock GL. Would love to add DSP but I know that was a lot of work
mackwood
california
2003 jetta grey
i thought since it was a oem deck i wouldn't have to add the k line. i think its pin 7 of the obd port. but where does that wire go to. can i just use regular wire?
i got it pin7(obd) to pin 3 black connector.thasnks
mackwood
california
2003 jetta grey
OK got the k wire installed and the unit came with 05407. sounded great. so i changed it to 01411. didn't sound as goos. not as much bass. so then i changed it to 05401. still sounds as great as when i put it in. i will leave it like that.. but what does the 5 stand for.
mackwood
california
2003 jetta grey
i will try that today. i don't have cd or fis so i changed the 7 to a 1. but i was listening to it today and i think it sounded better with the 7. who knows , i think i'm hearing things
skodalux
Belgium
tdi 130cv PD
hello, and good morning
I have a little probleme with my mfd1, can you help me?
I explain, I bougt the unit in germany, all is runing but the car situation is not right , I have a mistake from 350 meters,
After have read your topic here, i have try to recode the unit , but the code stay in 0000 and then impossible to have the tracking with gala the last number possible is 12.
impossible to access to the coding and put 0001.
I have also test to change the diameter weels and it doesn't reactualise automatiquely after several kilmometers.for me the GPS stay in abs impuls mode .
have you a idee for me.
thanks at all
skodalux
