krisclewell
I've called over 9000 places about head studs this morning. No one has a set. Does anyone have a line on some or can help? Seems like there must be a shortage....
If ECS has them, why does their product say "ships by December 20"? HmmmECS has them in stock as well
https://www.ecstuning.com/b-arp-parts/cylinder-head-stud-set/204-4706~arp/
Backorder means, literally, not in stock.ID parts has them on backorder but not out of stock
I highly suspect your attitude sucks. Call these places and see if they're in stock. They're not. I even called ARP. They're backordered until March. But thanks for all the advice sherlock.I highly suspect your claims as fiction.
urotuning and europartimport both list them as in stock
took me all of 2 minutes to look for you.
have you actually tried ordering any of them or did you give up after 9,000 tries!!!!!!!!!
besides, why do you need them? you do know you cant just drop them in and expect them to work off the bat. the block and head must be prepped and honed for them or you get distortions.
If you search for the part number
204-4706
you will find a few listings on ebay as well. One is in CA but looks like its the last one in stock in the USA so i would hurry and order what you can.
I am going to be running a much larger turbo with more boost. Was just hoping for some extra security.As a counter point... I installed my head studs nearly two years ago using the method in this link here, and have had zero issues.
ARP2000 ALH Head Stud Install (trying to stop a coolant leak)
So as some of you may be aware based on my other posts, I have a coolant leak. I figure there's a good chance that it can be fixed simply by swapping my existing head bolts for the new ARP2000 set because: It only leaks under high boost/high RPM situations. If I drive it real easy, it won't...forums.tdiclub.com
I previously wasn't having any head gasket issues, these were installed as a prevention measure since I was upping my engines power. Your mileage may vary.
Someone dmd me. Thanks guys.Lol @ ecstuning saying they are "in stock" . Hahahahahaaa
