Finally got around to taking some pics
stuffed another suction line into the sender, took some brain work to figure out how best to do it, was expecting the return to go to a jet pump sorta thing but it doesn't...
'Ere's the pump.
yup, in the cabin, couldn't find a nice convenient place for it underneath. Note to anyone else in the future, buy an inline pump shaped like an 044 or whatever, there's a spot molded into the tank where you can stick it underneath. This one's too big for that space.
Ran the fuel line down the rocker and out a rust hole in the front wheel well.
Tried a bunch to snake the push lock through the normal fuel line channel, but it just wouldn't squeeze through.
Haven't really got any more on the pump sorted, just did that all today.
There's a pic of the back, just because I had the camera out and all, gouges and dings are from the 5-6 engines and transmissions that've been back there, among tons of other assorted stuff.
Had to put a "steam line" onto the IC, the fittings are drilled halfway up the end tanks. Great if you're putting it on end, but terrible if you've got it flat.
Passat coolant tank fits. Thinking about running just the one and getting rid of the golf one, but that's something that'll come later if it does.
1st gen prius pump
black is power white is ground, wire it up with romex to get in the right mindset, if you have to.
Look no further than the lower right to see my beautiful ground point. Ended up powering it straight from the switched lug under the dash, figured why complicate it with switches to run it at partial speed or whatever.
What a rats nest. Sometimes I think about just dumping in a n/a 1.6D in.
Got the inverter rad from a 1st gen prius too. Fits real nice, just gotta hack out a bunch of plastic to get it to fit, can barely even tell it's there. Stealthy. Style. Class. Panache.
Ended up making the filter head. 2.5 hours or so, cranked out on a taiwanese jet lathe and an italian BP 1J clone mill
because I found a filter that is 6 micron rated, with a drain on it, only problem is it's a real wierd 15/16"-16 thread, thus making a filter base when one would be easier to buy
Not that the drain will ever get used, it just makes me feel better for some reason or another. Haven't ever touched the one on the stock filter... Maybe I'm kinda dumb sometimes.
