Ugh, got lots of solid fuel coming out the lines, no bubbles, tighten down the line nuts, no smoke, no wet GPs
Maybe a junk pump head that can't build enough pressure to open the injectors? Hell. Gonna smack the top cover over toward the rear of the engine, more fuel more better? I know on mechanicals you want to bleed it with a brick on the go pedal, but don't really know what the cranking fuel maps look like beyond the one with temperature that everyone changes to 'fix' the 'hot start issue'.
ETA: maybe I put the cam plate in 180 off shooting the fuel right out the exhaust valve? Unlikely but worth a shot. Flopped the pulley around on the belt, there's 6 slots in it, but only three line up with the IP's bolt holes, didn't find a chainsaw file in time to remedy that while it was out, so I've gotta do that mess AGAIN because it still doesn't smoke white, even with the top cover bumped to the end of its slots.
Figured out the tensioner can be done with a snap ring pliers, only a moderate pain.
I think I'll pull the IP pulley again, head over to my dad's, fix the slots with the mill and then try whatever you guys have got for me when I get back, because my next guess is pulling the pump again to see if the control collar siezed to a no-fuel position or something. Could see that happening and it still making enough pressure to get past the DVs but not the injectors.
