I have been reading an searching...etc but I am still looking for a simple build recipe.
I am installing a 2003 ALH in a jet boat. That means that it will be a stand alone engine with nothing but a driveshaft hooked to the flywheel. No clutch, no suspension, and best of all no space limitations. The doghouse that the engine will live in can be any size.
The engine is from a 2003 jetta with a little less than 200k. My goal is to make as much power as I can that the engine can sustain. In a jet boat the higher the rpm's go the more power is absorbed by the pump. So I can change the impeller to raise or lower the amount of power used but not change the power absorption curve.
My goal would be to make between 150-200hp for a long period of time (potentially hours) at about 2500-3200 rpm without killing the engine, excessive egt's...etc
I have an 11mm pump from a rover 300tdi. I can fabricate well enough to make an exhaust manifold to attach to any turbo. I also have a water to air intercooler that will have cold lake water running through it (usually 70*f or less)
My idea is to use R520 nozzles and a big turbo but I really don't know enough about diesels to make this up my self.
What I need is a basic prescription to follow for what turbo and nozzles...etc to make this power and lower get goal.
I was recommended a k20-24 hybrid turbo and R520 nozzles but without much of an idea what it would do.
Any help would be appreciated.
Thanks, Matt.
Thanks, Matt.
