Side mirrors stuck
2003_unicorns
Virginia
2003 Jetta Wagon manual & 2003 Golf 2dr. manual
Hi,
Was wondering if there was a way to unstick them without breaking them.
The power mirrors work on both but they will not fold in.
Thanks.
P2B
Toronto & Muskoka, Canada
Hi,
Thanks.
Trying gently wiggling them back and forth a bit at a time, you might be able to free up the oxidized aluminium - but there is definitely a risk of breakage. You can take the cover off to see how badly the mechanism has rotted.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Shoot some PB Blaster in there daily then tap the base. Clean the excess off the finish.
snakeye
Montreal, Canada
2003 Jetta and Wagon, GLS 5sp
Great for rust, won't do **** on oxidized aluminium ;)
Huh? What's the difference? PB blaster is a penetrating oil; why wouldn't it work at loosening up seized parts, regardless of the metal it's being used on?
P2B
The parts are usually disintegrating more than seized. Penetrating oil tends to turn the aluminium oxide into a paste.
2003_unicorns
Virginia
Thanks all. Are you talking about the black cover at the top of the mirror itself?
BobnOH
not-a-mechanic
central Ohio
2 pieces of cast with nubs is what is stuck. The bottom one is fastened thru the door.
Broke mine (99.5) when it was new. Was able to repair without popping off the door card.
Similar to what happens with the wiper motor, cast aluminum gets fused together.
