Obergruppenfuhrer
Just got around to programing the garage door opener on the TDI SEL Passat and I can't find info on how to do it, can somebody inform me where to find it Please!
I did mine (two separate garage door openers) in about 10 minutes. It's clearly explained in the manual. Just keep in mind that most door openers are rolling code so you will need BOTH the original remote and access to the programming button on the door opener motor.In the manual...and why are you shouting at us? It's not our fault...really...unless this is some sort of emergency...
So that's what is in the black case located in the glovebox.Now just to defend the guy a little, just a little.
The manual is HUGE. Well organized and indexed, yet it can appear overwhelming.
I followed the procedure without issue with rolling and non rolling remotes and they all work great now.
Yes I found it just where you said it would be in the glove box, only thing is its kind of out of sight in the upper part of the glove box.LOL! Yes in the glove compartment if the dealer put it there.
