LOL!!!!!Trailer Assist looks awesome!
https://youtu.be/mxr83Vkrh00?t=6
Very nice. Any mods to the car? Also how much does the said trailer weigh? What's the furthest you've taken it.The post of mine about the car running like crap after towing. I found the problem...
It wasn't towing the other car that had anything to do with it. It did it again a couple days ago. After a lot of searching, I found where someone cut into a couple of the wires harness-side of the injection pump plug and the wires apparently never were reconnected correctly. This specific wire that was almost apart again, according to the wiring diagrams, is some kind of a voltage metering sensor for the quantity adjuster. I'll be soldering them together better this weekend.
I shall tow again soon
Here's a little tow porn for you today.
That's my hard-side popup camper.
Car is as modded as can be for 275,000 miles on the original vnt-15.Very nice. Any mods to the car? Also how much does the said trailer weigh? What's the furthest you've taken it.
Sent from my VS986 using Tapatalk
Wow that's some hard core modding lol. Great looking set up!Car is as modded as can be for 275,000 miles on the original vnt-15.
I dabble a little (read: A LOT!) in computer programming (read "screwing with stuff I shouldn't).
Anyway, I have .216 injectors, perf clutch, straight-through exhaust, & the equivalent of a Malone Stage 3, just fully written by me (advanced timing, no EGR, dynamic Idle, 18.5 psi max boost, greatly increased fueling, increased glow plug duration, increased coolant glow plug duration, and a few other goodies).
I built a 2" front, 2.5" rear lift kit (to save the aluminum oil pan and for towing). The trailer hitch has been reinforced with a couple extra mounts on the underside of the body for increased rigidity.
Near future, I will be installing a front mount intercooler and 2.5" piping, black steelies with 215/65r16 rubber to give me another inch of ground clearance. I'll be getting 20mm spacers to go behind the steelies to put them out to the edge of the fenders.
I've towed it a couple hours away from the house a few times. Nothing major, yet. My emergency brake cable popped on me a few months ago and I want to get that fixed before a big family trip to the Smokey Mountains.
It's been a slow work in progress. I can't seem to ever be satisfied with what I have. It always has to be better. It's a fault more than an asset.Wow that's some hard core modding lol. Great looking set up!
Cripes that's a big load! I think you definitely take the prize so far. What are the published towing weight limits for the Passat wagon? Are they they same as the Jetta?
I only use it off road to connect my 3x6 gardening trailer when I want to carry chain saws and other tools on the small trailer and fill the big trailer with brush and debris.What do you connect to the ball on the trailer? Tandem tow something light?
Awesome picture! How heavy would you estimate the load to have been?https://goo.gl/photos/kzCHDiEvXan1d6hv7
Hoping this image shows up. It's a Bora TDI I spotted last month travelling up towards the Chilean/Argentinian border. This stretch of road is here, not sure if link will work: https://www.google.ca/maps/dir/''/-...6!4m5!1m3!2m2!1d-70.1452723!2d-32.8612517!1m0
But it a crazy stretch of road of 30+ switchback and BIG elevation gain. Near the Portillo Ski Resort in Chile, by the Libertadores boarder crossing with Argentina. I couldn't believe my eyes!!
Great picture and map link. If you click on google earth and then the pictures at the bottom, you get a great shot of one end of the road. My wife would probably decide to walk instead of ride with me on that one.https://goo.gl/photos/kzCHDiEvXan1d6hv7
