coalminer16
Diesel mower
Sent from my SM-G950U using Tapatalk
Sweet! Here is a picture of my gasoline powered D110 which regularly travels 60 miles or 100 km round trip to keep the lawn looking perfect out at my wife's grandfather's house. Long story. Also, never mind the giant magnet powered by the giant lemon on the roof racks. This was taken the day before I left for the Great Lakes Mistake LeMONS Rally.Diesel mower
I'm not sure when VW started saying don't tow with the dsg, but for my 10, it says it's capable of 1500 pounds. IIRC, the European rating was 1500kg or 3300 pounds. If you're not having issues with the ALH, I think you'll be fine with more power and the dsg.We're thinking of replacing the ALH/5MT Golf with a 2011-14 JSW TDI/DSG. Can it handle towing the Scamp 13? Thinking of engine emission durability and auto tranny durability.
The Golf continues to tow very well, but at 280k it's starting to look tatty.
Thanks for any insights!
https://drive.google.com/file/d/1umNYqsfac73K47O8JnSL2U0DQCY5QO-P/view?usp=sharing
What's the normal coolant temp for when you're towing.
I am really happy with the 2" tesla receiver, it's really a proper 2" hitch solution without any custom parts. I've done a few long trips towing my sailboat with it since the install. A huge advantage is that I can get the ball height just right for different trailers.Hi, just wondering how you're getting along with the 2'' receiver from Tesla? i was inspired by your post and have found one. Planning on this set up for my mk6 Golf. Would be great to hear about your experience with it so far. Thanks.
The newer cars are different than yours. They seem to have higher temps than the older cars by some degree. My old 2013 Passat tdi and now my 2015 Beetle tdi run around +/- 203F on a normal basis. Others have reported running hotter temps when towing of around +/- 230F.IMO it should be impossible to exceed 100C, or else you have some components not in top shape. I can climb a long steep grade at full throttle with the A/C on and a trailer, and not get over 100C (usually only 95C max) in my '01 TDI golf. If you are getting higher temps I'd check that both fans work, and if so replace the radiator and thermostat.
It also depends on what your source of information is. If I were to go by the gauge on the dash it did not really move from 90C when it showed 103C on the OBD gaugeThe newer cars are different than yours. They seem to have higher temps than the older cars by some degree. My old 2013 Passat tdi and now my 2015 Beetle tdi run around +/- 203F on a normal basis. Others have reported running hotter temps when towing of around +/- 230F.
What sort of weight is the Scamp coming in at? Looking forward to seeing the pics.A pic from our recent trip to Florida. This is actually somewhere in South Carolina, near Lake Wateree.
The 01 Golf pulling the freshly painted '82? 83? Scamp travel trailer.
https://drive.google.com/file/d/1OI6ReFHkd3ItjQubfJSij8VIajxzCjrV/view?usp=sharing
Edit: lemme try to get the pic to show up....
Here are your photos.A pic from our recent trip to Florida. This is actually somewhere in South Carolina, near Lake Wateree.
https://photos.app.goo.gl/Y7v84eGn8u3afxfSA
Sharp paint job.A pic from our recent trip to Florida. This is actually somewhere in South Carolina, near Lake Wateree.
I am not too sure what the Westfalia module does.@pb_nb
I take it you dont have the Westfalia module? Trailer stability control would've been nice in That situation for you.
Yeah so the module is the correct/OEM way of towing with the vws. It ties into the canbus system and provided feature such as trailer stability control. Stability control for your trailer, so if it wags the tail of the dog etc, the stability control system brings it under control. It ties in the alarm system too and others depending on what modules you have. Like automatic shock leveling and remapping of the engine to towI am not too sure what the Westfalia module does.
When we first started towing, I was trying to keep the load on the hitch relatively light so I loaded most of our stuff in the middle so I could pickup the hitch easily. Then when it happened we were doing about 70mph and got passed by a tractor trailer while there was a cross wind. Since then we have changed the trailer wheels to low profile wheels to eliminate the sloppy side to side movement from the 13" radial tires. We have a sway controller which is tightened up when used.
I can also use the brake controller to apply the trailer brakes if it was to happen again.
It really comes down to making sure there is enough tongue weight on the hitch.
Now that we have had the trailer for a few years, we feel very comfortable pulling it anywhere. We haven't had any more swaying fish tailing issues but we did work on the whole towing approach to fine tune our situation.
How to post pics in my signature below.Somebody smarter than me will hafta make the pic show up. At least the link seems to work now.
I am pretty sure VW or Westfalia wouldn't have any modules for the MK4 cars. The supporting systems just aren't in the cars to monitor all the bells and whistles.
