As I found out with my Homelink mod, if you are using LED lamps in your make up lights, the above mod will not work due to the curcuit used by VW. As some of you may be aware, if the wire is brown on our cars, it is a ground wire. If it is a brown wire with a colored stripe, it is a "switched" ground. If you observe the stock sunvisor wiring, you will see that the two wires that run to the switch for the makeup mirror lamp are brown and brown/white. Since VW is only giving the makeup light ground via the switch, power is only available to the Homelink by going through the incandescent lamp used for the makeup light. This works fine until the light burns out, or you use an LED, like I did, which prevents the 12VDC from going to the Homelink as wired in the above post. (LEDs are one way devices, where an incandescent lamp goes both ways) Solution? Run the VW repair wire used in pin three of the Homelink visor over to the makeup lamp socket, there you will find the red/blue wire which feeds this circuit in the first place, tap into that and you will not have to worry about lamp failure or the use of LEDs for your interior lighting. The wire used for the power to the Homelink sunvisor is a red/blue.
The LEDs I am using were purchased from 42Draft and really make for a nice cool white look in the interior. (or any other color you might like)
By the way, the Homelink transmitter is a GM part!
You can carefully remove the cover on the Homelink and the unit will snap out. The Homelink unit is GM part number 15015905. Doing a search revealed that these are available for around $87. Probably can find these for less somewhere else. So if your Homelink fails or does not work, you might be able to find this in a GM vehicle for allot less money than replacing the whole sunvisor. Hope this helps out anyone looking to do this mod.
I got my Homelink all programed up and it works great! Search around on car parts.com I got mine for $65 shipped. I believe these were only used on Passat GLX's and W8's which should help to limit your search.
