Shifter identity
harley1955
Taylorville, Illinois
2001 Jetta GLS
2001 Jetta TDI that started out as an auto and I had it converted to a manual by Kansas City TDI. Trans and shifter came from a member here. Had this done about 10 yrs ago. Trans has been kinda hard to get into 5th lately so thought I might need to adjust the shifter. When it goes to the right and up for 5th the bottom of it hits on the left side. Anyone recognize this shifter and how to adjust it? O2J EGR Trans.
Windex
Cambridge
05 B5V 01E FRF
That and the double pivot instead of the ball-style level on the inside.
OP - find the parts needed to swap this over to the newer 2000 and up shifter style, you will see a marked improvement in the shift quality.
Note that you can use the shifter mechanism from a gas or diesel transmission.
Only hard-to-get part is the sector shaft that goes down into the transmission and the assosiacted bushing from the bottom of the trans (two bolts - VW logo) - not all junkyards want to sell that part as it makes the transmission hard to sell after.
mrGutWrench
Carrboro, NC
'03 Jetta Wagon, 5-speed, 563K Miles (July '23)
I recently broke one of the shift cables (worn out at 550,000 miles) and as part of that repair rebuilt the shifter box with the Diesel-Geek upgrade. I suspect that that upgrade is only for the 2000MY+ plus type, but it's a great improvement.
As to your adjustment question, the later type has two "eyes". When you shift it to a certain position, the two eyes line up -- put a small drill bit (or the special tool) through the eyes to hold it in line and follow the adjustment from there. It's quick and easy and makes a lot of difference to smoothness and correct shift points. (I think the adjustment procedure is a "sticky" on a post on this forum, if not, it's often shown on general VW websites.
The amended adjustment is another good reason to change to the later shifter parts.
harley1955
2001 Jetta GLS
Yes I've seen the vids on youtube, knew something was not right when mine didn't look like that.
harley1955
2001 Jetta GLS
So I did a search on ebay and came up with these:
I assume those are the parts I will need?
Windex
Cambridge
05 B5V 01E FRF
Yes. There is one more item missing. A bracket on the top of the transmission that holds the cables in place. That bracket is held in place with 3 bolts and has two holes... One for each cable end.
The bracket is different between your current shifter style and the newer style.
