Seeking competant, honest, reasonably-priced auto service. Am I asking too much?
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
Hi there,
Used to be on these forums here a lot but haven't for quite some time.
As the title says, I'm looking for a mechanic/technician who's competant, honest and reasonably-priced in the Barrie area. Am I asking for too miuch?
Can I get some recommendations or advice on a good, reliable service shop in or around the Barrie area, or even an independent mechanic who can do some wrenching on myh '02 Golf TDI?
Thanks, Gary
CanadianALH
Canada
2002 Jetta 5spd 2006 Jetta DSG (wifes)
Hi there,
Thanks, Gary
@MrCypherr and @P2B are Ontario boys I’m sure they will have a good starting point
P2B
Toronto & Muskoka, Canada
Club members have had good things to say about V Dubbs in Innisfil for more than 10 years, although I have never used them myself.
My go to guy for anything I don't want to do myself is Perjad at Precision Tuning in Vaughan, also in business for many years.
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
Thank you for the quick response and recommendations, gentleman. I do appreciate your help. I did do business several times a few years ago with VDubbs and the personnel did work which resulted in no comebacks so the competancy seemed fine. But there was not one instance where I did not get the dreaded phone call reporting the need for additional work and his prices were definitely no bargain. Plus he complained that he didn't like working on VWs over 20 years old. I did not get the warm and wanted feeling, that's for sure. During COVID he treated customers or me at least like I had the bubonic plague. No entry; drop keys through the door slot, payment over the phone. Key and work order in car upon retrieval. A bit weird.
I miss the old days of wrenching with TDI club members. I guess those are long gone. Is that correct?
burpod
teh stallionz!!1
cape cod, ma
time to do it yourself. what do you need done? almost all the info is on here. most of it is quite easy if you hace a couple tools
MrCypherr
Ontario
Mk6 Wagon
Id goto Precision Tuning if thats within your travel range. Heard nothing but good things with them. Not sure Barrie area, Unless you can find a local member thats willing to help with some things.
Windex
Cambridge
05 B5V 01E FRF
I do my own wrenching, but point friends and family to perjad @ precision. Have not had a bad outcome yet. Latest was my nephews newer golf going to perjad last month
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
Precision Tuning sounds good, however, Vaughn is a considerable distance. Not like I can just go home - I'd have to wait there or at least the vicinity.
Wish there was somewhere recommended in or around Barrie.
Latest problem is the fuel tank straps both dissolved - corroded. Currently using a pair of ratchet straps holding up the tank. But the cross member mid-car I'm using for support is also badly corroded and it's the only spot I can see to hook on to. The vile substance that dissolves snow does an equally good if not better job at dissolving metal.
Also getting the flashing red light (master caution?) which of course the owner's manual offers no clue as to the cause. Coolant and oil are both normal.
There's also a loud hissing noise on acceleration - likely a turbo-related air leak either charge-air or exhaust side. Could that cause the flashing red light?
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
The red flashing symbol is in the speedo dial. I believe it's the low coolant alarm, although it's circular in shape and not the shape illustrated in the manual. The coolant is at normal level, so I don't know if that is specifically what the alarm indicates. My owner's manual does not specifically show this symbol or what it means.
P2B
Thanks, man! It's the brake system warning light. Appreciate your help and everyone elses as well. Thank you>
Flashing brake system light means low brake fluid, handbrake not fully disengaged, or (in conjunction with ABS light) two or more ABS system faults. Could also be a wiring issue with fluid level sensor or handbrake switch.
Johhny04
Markham, Ontario
2003 Jetta TDi
With all these issues you're mentioning, be ready for a sizeable $ estimate for repairs by a shop. If completing the work yourself, it might make economical sense but with a 22 year old car and the items you've mentioned above, don't be shocked at what you get quoted to repair the issues.
P2B
The OE straps appear to be NLA and aftermarket were well over $100. I used galvanized pipe strapping from Home Depot, ten bucks with enough left over to do a couple more cars.
.... Plus he complained that he didn't like working on VWs over 20 years old....
Can't imagine why...
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
Kudos to you - absolutely brilliant idea to use galvanized pipe strapping rather than the obscenely-priced aftermarket straps. So obvious yet I never thought of it or doing that. But why not? Thanks for that invaluable tip! Really appreciate it!
Muggins
Barrie, Canada
02 Golf GL 4dr 5spd
Ya me neither, given the car is pretty dead simple compared to modern technology and the stuff I've listed is likely not terribly involved. But I guess no excuse is needed to get shafted nowadays. Covid, Covid hangover, supply chain, yadda yadda yadda.
P2B
Unfortunately even jobs that should be straightforward can easily become a nightmare on cars driven through 20 Ontario winters. It's hardly surprising that a busy shop would prefer less crusty cars with more predictable job times.
Nuje
Island near Vancouver
Having told people "oh yeah - shouldn't take more than "x" hours"; only to have a captive nut break off inside the subframe, a tie-rod locknut that wouldn't budge, I know of what you speak.
It really is shocking working on a Mk4 car that's spent its whole life here on the west coast vs. one that spent even a few winters where real winter happens.
Yeah, I don't think I'd take on a car that old in that part of the world either. Rust changes everything... it'll quadruple the job time with one broken bolt. We're so swamped here we turn away a lot of work for all kinds of reasons. Age of the vehicle is certainly one of them.
The ALH cars ARE very simple, but now getting a lot of parts is impossible (the NLA list grows daily), and as stated in your area rust is going to be an issue. We don't have that level of road salt here, and Volkswagens hold up better than some others.
MrCypherr
Ontario
Mk6 Wagon
I know there is a decent amount of scrapyards and dismantling business' locally that usually have a great amount of older parts for these cars. Check out Next Gen VW Dismantling on facebook or some local scrapyards. They will be used parts but its better than not having parts at all.
CanadianALH
Canada
I think Canada catalyst is localish to you guys.
MrCypherr
Ontario
Mk6 Wagon
They are but more south kind of which would be a 3 hour drive for OP. I know there are a few that are closer to OP so he can drive and pick up parts in person which is what I would recommend to see the condition of the parts and whatnot.
GP_RZ
Alliston, Ontario
2003 Jetta Wagon 5 speed
Thats to bad u had a bad experience with Mike @ V Dubbs, he has been decent with me, did my 5 speed swap and timing belt and a boat load of other things, He did mention to me last year that he will only be focusing on the newer stuff as parts availability for the MK4's. I do understand him some as a Painter/prep at a body shop I cringe when i see older stuff roll into the shop.
Yeah, parts availability is a real issue. I have a 2003 J-wagon here with 338k, and a 2006 sedan here with 340k. Mostly normal PM stuff for both, and I'm able to easily get everything I need. But the trim parts as well as some odd parts you run across in need of (like fuel lines under the car that get damaged from things) is all just NLA.
