USMCFieldMP
The motorsports side of the forum seems a little dead; thought I'd try to liven it up a bit. I have my first track day on August 5th - six 15-minute stints - at Motorsport Ranch in Cresson, Texas.
I'm curious about anything in particular I should watch for or keep an eye on. EGT's, anything DPF related, IAT's, etc. The lack of an oil temp gauge is a little upsetting, but I'm sure it'll be fine. I have a VCDS, so I can check things (although I am new to it, so still learning). I'm in Texas, so ambient is undoubtedly going to be mid to high 90's; potentially even triple digits.
As far as tire pressure goes, from the reading I've done, it appears that I should try to keep hot pressures below 40 psi? Check before and after each stint and keep track of the changes?
I've autocrossed the car a handful of times and have a half dozen laps on a track in a Ferrari 458, so I'm no stranger to throwing a car through some corners, just curious about anything specific to watch for on the TDI's.
The car is a 2014 Jetta TDI with 47,000 miles and these modifications:
- KermaTDI Tune
- KermaTDI Intake
- ECS V4 Rotors
- Hawk HPS 5.0 Pads
- Tyrolsport Brake Caliper Stiffening Kit
- ATE Type 200 Brake Fluid
- Euro Short Shift Linkage w/ Solid Cable & Mounting Bracket Bushings
- BFI Weighted Shift Knob
- Koni Coilovers
- ECS End Links
- 17x8 RPF-1's
- 225/45R17 Goodyear Eagle F1 Asymmetric 3's
- Corner Balance & Alignment by Texas Track Works
