Hello, new tdiclub forum member here from the DFW area. Recently purchased a 2013 JSW TDI that sat for 3 years according to the carfax.
The only issue I'm having is that the seat recline switch and seat heater on the drivers side doesn't work. The passenger side seems to work fine. The seat is reclined a bit too far and it makes driving a bit uncomfortable.
I posted this on /r/tdi and a user there mentioned that I should check and re-check fuses, so I bought a test light and all fuses on the left side of the dash and under the hood seem to be working as expected.
I can't seem to find a decent fuse map that may tell me where the fuse for this is. I found some old tdiclub posts with old fuse panel images, but all the fuses seem to be OK. I think there may be another area under the dash with the seat fuses, but I can't seem to find the exact area to see if that's actually the case or not.
I did notice some green/blue flaky corrosion when I move the seat all the way back and remove the little flap of carpet where the electrical connections for the seat are. I've removed all the connections and sprayed contact cleaner there but that hasn't seemed to help. Maybe a previous owner spilled a drink or something? I see no signs of corrosion anywhere else on the car that I can tell.
I did ask the dealer about this but they want $300 just to diagnose it, which I may eventually do. I'm pretty handy, just new to electrical issues, so I thought I'd seek out advice on this before I take it in.
Thanks for any advice
