Seat Leon 2.0 TDI
MylesJM
West Midlands
2.0 PD140 BKD
So originally I had a Seat Leon 2.0 TDI with the Siemens injectors & they had went kaput so I thought I would do the injector BKD conversion & everything is great so far baring 1 issue I am experiencing when I am up to temperature.
I have very delayed throttle response when trying to go full throttle but if I were to feather the pedal it will respond almost instantly
This issue does not happen when the car is cold.
When car is warm:
Warm full throttle
When car is cold/not up to temperature:
Warm coldish throttle
I've looked on VCDS and the pedal is reading correctly, the injectors are moving so I'm abit confused
When doing the BKD Injector conversion I bought a Stage 1 demobilized ECU and I flashed it back to the original file the car would of came with from factory and the problem is still there.
Any thoughts on what else I can check? Thank you in advance.
