MaroonCordoba
Hi! Hoping someone can help…. I have a ‘98 Seat Cordoba with the 1.9 TDI, I believe it’s an AHU, 90hp.
I had an intermittent issue that just got less so… and maybe easier to diagnose. After several spurious observations I have pinned down the following:
- starts as normal. If driven immediately it drives fine
- if left to idle, or if the accelerator is released for more than a few seconds when driving it enters a ‘limp mode’. Rpm is a steadyish 1200 and the glow light starts flashing after a couple of minutes. Throttle unresponsive.
- Stopping ignition off for a couple of minutes and it has ‘reset’. But it needs a couple of minutes.
- I have two switches on the brake pedal (and one on the clutch?!). The fault is the same with either or both switches disconnected. Also same with the non-brake-light switch bridged.
- when first started the engine will still rev with the brake pedal pressed. When driving if the brake pedal is pressed sometimes it cuts the power, sometimes not.
- if the accelerator pedal sensor is disconnected and car started the revs rise to 1200 almost immediately, if connected it takes maybe ten seconds or more for this to happen.
I’m thinking it’s either an issue with the pedal sensor, or the ECU but would be really grateful for any pointers. After changing numerous air flow meters, and a few months ago a crank position sensor I vowed to go down the MTDI route…. But if I can fix it….
Thanks in advance!
Thanks in advance!
