In hindsight I should have run through all 3 tunes on both intakes - it would have been easy enough to do, just didn't think of it at the time
Brum, I understand what you're saying, but am trying to figure out how significant those differences are at 100% throttle. The three different tunes behave quite differently in how they control boost. If you look at the above exhaust manifold pressure measurements done during the dyno runs, it would suggest that exhaust manifold pressures are not significantly different, beyond spool up. If you look at the VNT actuator vacuum in the data above (Pink trace at the bottom), the ALH intake runs the actuator in a more closed position, particularly in the 2000-2500 RPM range on the same tune with the SDI. VNT position does not equal a given exahust or intake pressure - you can have widely different intake and exhaust pressures for any given VNT position depending on engine RPM and load.
The data also shows that the exhaust pressures are not crazy high on the 17 hot side as some have suggested. Only exceeding boost pressures above 3500 RPM and then only by a few psi. Then again, I'm only putting down 125-130 HP as well so maybe that has more to do with it
Like TDIMeister stated, this is just one sample with data. More people doing comparative dyno testing will support or conflict with my data. I don't expect that there will be a big number of people able to do back to back dyno's like I did, but even same car, same dyno should give some indication as to what's going on.
Taking a step back and looking at this whole thing...
1) Regardless of what different variables are at play (tune(s) need adjustment, how tightly it was/was not strapped to the rollers, phase of the moon, etc) there is just not a big difference in power between two very different intake manifold designs. The dyno data shows it and my super accurate and repeatable NIST calibrated butt dyno can't tell any difference driving around with either manifold (and I can definately tell you within 1 block which tune I'm driving and there's not that much difference in the power of the tunes either).
2) Maybe my car is an anomoly - Given many other members cars with similar equipment making ~175 HP or so, maybe there's some other limiting factor that is not letting the intake manifold differences show through. If I remember right, someone at the dyno day had PP520's, 10mm, 17/22, RC4 or 5 and put down 140 HP/300 ft-lbf.
I'll do more dyno testing if I get the opportunity - there's
a shop up in West Bend that has a similar Mustang dyno as the one at UWP. Most of my weekends are pretty booked up for the summer, but maybe I can run all 3 tunes on each intake in 1-2 hours while it stays strapped down to the dyno. But if #2 is correct above, it might be a waste of time/effort/$$$
