Dimitri16V
I have this noise for a year . sounds like metal parts rubbing together. gear in or out , it is speed dependant
Changed brakes discs, pads , right front bearing , noise still there
it goes away when I turn slightly to the right , becomes worse when turning left . changes frequency going over bumps or when the front suspension travel is excessive
checked the flanges on the tranny , no play
thinking outer joint , boots were never torn . no cluncking noises when turning full steering
car has had SMF conversion for 100K now
