Scrapping noise from driveline
Dimitri16V
DE
01 Golf, 04 Golf
I have this noise for a year . sounds like metal parts rubbing together. gear in or out , it is speed dependant
Changed brakes discs, pads , right front bearing , noise still there
it goes away when I turn slightly to the right , becomes worse when turning left . changes frequency going over bumps or when the front suspension travel is excessive
checked the flanges on the tranny , no play
thinking outer joint , boots were never torn . no cluncking noises when turning full steering
car has had SMF conversion for 100K now
Dimitri16V
DE
01 Golf, 04 Golf
no, factory belly pan
noise sounds like metal parts rubbing together , it changes with speed
I will put it on jack stands tomorrow and run it to see if I can pinpoint the source
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
I have the same noise, much worse when it sits for days. Always thought it was beat-up brake dust shields, but I never looked at the exhaust for shielding.
Dimitri16V
DE
01 Golf, 04 Golf
at first I thought it was a dragging brake pad but both pads had similar wear
it is very audible from inside the cabin , I should be able to pinpoint it with the car on the stands
will update
Jesus Is Lord
Hersey, MI
2005 Passat TDI Wagon 144,000 2003 Eurovan VR6 2007 Touareg V10 TDI 158,000
I had that happen and it was just the rotor shields rubbing on the rotor. It was very loud.
Dimitri16V
DE
01 Golf, 04 Golf
no noise with car on the stands
I guess I will change the drivers wheel bearing too
Tdijarhead
Lawrenceville PA
Dust sheild or bearing would be my guess. I'd try bending the dust sheild back a bit, if you haven't already, it doesn't take much of a rub to make a pretty substantial noise. If there is nothing rubbing ,my next guess would be a wheel bearing.
Dimitri16V
DE
01 Golf, 04 Golf
I checked the dust shields on both sides they are straight and not touching anything
noise changes when suspension is compressed ( going over speed bumps )
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Sometimes it would be nice to have a midget that could fit in the engine compartment and pinpoint noises.
My guess is CV joints or wheel bearing. Since it actually changes frequency (instead of intensity only) on pumps, I would lean toward CV joint. Have you checked that you can't wobble your wheels on the bearings and that there is no improper suspension play? Having the alignment checked could be helpful as well.
bollweevil
Blue Grass Region, Ky
98 beetle tdi
Just repaired mine - it was left axle, loose w/stripped threads
Easy enough to inspect & retorque and see
I needed axle, bearing, and hub but all fixed and proper now
Dimitri16V
DE
01 Golf, 04 Golf
just finished mine
drivers bearing , outer race pitted
I replaced all ball joints , tie rod ends and found the axle shield rubbing on the metal part of the inner joint
Some of the low frequency noise was the bearing and the scraping noise was the axle shield. I use a 2.0 one and it has a metal part in it
on the positive side , the car feels tight and no more play in the steering
