Just purchased a 2014 Jetta Sportwagen TDI with an issue getting the H15 high beam lights to come on. I've done all the recommended checks and replacements (new low and high beam bulbs, checked all the fuses, replaced the steering column combination switch/stalk, and replaced the dash main light switch) with no positive results, which leads me to believe 1) the previous owner upgraded the headlights with programming, put the original headlights back on and didn't bother fixing the programming, or 2) the ECM is toast and should be replaced.
Either way, my scan tool is not up to the task to do any further diagnostics and need someone with a VCDS and experience using it. I live in Taylor 18517. Can you help?
