As I've come to expect, more issues.
I worked on the car during my lunch break today, trying to attach the control arm to the ball joint.
Turns out, the ball joint is too small for the control arm, it won't reach in far enough for the holes to align.
seriously, ***! So, I'm now going to get a new ball joint from the place i got the control arm... so that better freaking work.
Also, turns out that my front motor mount bracket is not the right one... or something. Because the hole in the scirocco engine mount is FAR too small for it. I know the mount is right, so my only conclusion is that the bracket is wrong... it was in a parts box in the back of the car along with a bunch of jetta parts, so it's not really that surprising =(
So, more delays -_- I'll do what I can in the meantime with the other parts.
Oh, an engine at work blew up today. The cummins engine in the crusher (it does exactly that, crushes big chunks of asphalt) blew a piston through the block. After we've removed it and put it back at least 6 times for oil leak issues... it just finished a full rebuild today with a new head and, no less than 10 minutes later. BOOM!
Pics to come:
That side's fine...
How's the other??
Upon closer inspection
That's the machine.
