Thank you kindly Sir..... that change has fixed my issue and I am now getting a proper reading.Sorry, the 'A' has to be a 1. I corrected it in the table a week or two ago, but you must have picked it up before then.
The name is just an identifier that helps you determine what you are looking at..... you can use anything you want for this as long as you know what it stands for.... also does it matter if I try to label it DPF for a name?
1550 F is where the limiter is set on my Malone stage 2 tune. I've seen as high as 1690 before the limiter has time to cut the fuel. Under 1500 is a good bet for towing.I have the OBD scanner an Tourque app. The boost doesn't spool up until usually about 2k. Isn't this normal? The hifghest I have seen is 18 or so on full tilt.
I mainly got it for towing. I have the EGT and 1st sensor after DPF set. EGT ranges from 400-1400 depending on throttle. !st sensor seems to stay around 600-700 until in regen then seems to stay about 1000-1300ish. What is TOO HIGH? I will be towing for the first time this weekend and wanted some insight.
This 1550F is just EGT not after DPF right? The EGT seems to fluctuate like crazy depending on throttle, of course. I thought it would be more of a gradual rise and fall.1550 F is where the limiter is set on my Malone stage 2 tune. I've seen as high as 1690 before the limiter has time to cut the fuel. Under 1500 is a good bet for towing.
Sent from my VS920 4G using Tapatalk
Yes that's the pre DPF limit. I know they have the limiter from the factory, but I'm not sure if it's the same as the tune or if the tune kicks it up a bit.This 1550F is just EGT not after DPF right? The EGT seems to fluctuate like crazy depending on throttle, of course. I thought it would be more of a gradual rise and fall.
I have a Stage 1.5 Malone. So it should have a safety shutoff programmed in also?
So just keep it a gear low as in always above 2k RPM and just drive? Will be pulling a 5x8 with two adults and two motorcycles.
Thanks for the info Bassman. Good to know as I may go with your mods later on. You say small trailer but it is pretty much bigger than the car.Yes that's the pre DPF limit. I know they have the limiter from the factory, but I'm not sure if it's the same as the tune or if the tune kicks it up a bit.
When I got my adapter and started playing around with torque, I noticed this about the temp too. The pre sensor is very very responsive, which is something I wasn't used to since all my EGT readings in the past have been from mechanical pyrometers. The post sensor on the other hand, doesn't seem to do much good at all now that I don't have a DPF. Its much less responsive than even my mechanical gauges, and I don't really use it at all.
Just a side note, after speaking with my tuner, I will be picking up a mechanical pyrometer when I have some extra cash. Some of these Stage 2 tunes are very aggressive (pretty sure mine is one of them) and need fueling dialed back a bit to keep temps under 1550. When I spoke to him about that, he also mentioned that the pre EGT sensor seems to be a common failure point, and the particular mode of failure is that they read a bit high. He said he had a customer with the same issues I and many others have had (hitting almost or above 1700) and this customer had a mechanical pyrometer as well. Turns out the pre EGT sensor wasn't giving the right reading. That may or may not be my issue, but now that the accuracy of these OEM sensors has come into question, I'd like to get an old school mechanical one.
2000-4000 RPM to keep you in boost and you'll be fine. Just watch the EGT on the hills. The only time I hit the limiter is WOT and I doubt that little trailer would require that much throttle input.
You most likely won't have to pull over (unless it's an extreme grade and your towing over the load limit). Down shift if possible, and/or let off the throttle to slow down.Thanks for the info Bassman. Good to know as I may go with your mods later on. You say small trailer but it is pretty much bigger than the car.
One more question. You say stay between 2-4 which is my plan. And to also watch the EGT on hills. So what do I do if it starts to get really high, downshift or pull over? Sorry for all the stupid questions.
has anyone been able to convert the temperature readings to fahrenheit for the people in the US not accustomed to celsius?Here is an overview of what I found so far; exhaust gas temperatures are from a post by 'hardtimes', and PID assignments from the Wikipedia OBD II entry.
I didn't try to confirm variables that are already provided by the standard Scangauge output. For 7A (DPF info) I'm still in the dark as far as the actual meaning goes. For 6D (fuel pressure) I'm guessing the units are bar because numerically it would make sense. Same reasoning for the EPR units.
Update 2013-3-13: RXF for PID 5E (fuel flow) should be 0441455E, instead of 0441055E, to get the correct decimal point placement in liter/hourCode:TXD is 07DF01+PID name PID RXF RXD MTH units comment TIM 1F 0441051F 2810 000100010000 s seconds since engine start BAR 33 04410533 2808 000100010000 kPa atmospheric pressure CAT 3C 0441053C 2810 0001000AFFD8 ºC DPF temperature FUF 5E 0441455E 2810 000500010000 L/hr fuel flow TRQ 62 04410562 2808 00010001FF83 % percent of actual torque FPa 6D 0541066D 3810 0001000A0000 bar Requested fuel pressure (<=1755) FPb 6D 0541066D 4810 0001000A0000 bar Actual fuel pressure (<=1740) BP1 70 05414670 3810 000100200000 bar requested manifold pressure ('4670' for hundredth BP2 70 05414670 4810 000100200000 bar actual manifold pressure BP1 70 05418670 3810 00910C800000 psi requested manifold pressure ('8670' for tenth BP2 70 05418670 4810 00910C800000 psi actual manifold pressure BP1 70 05418670 3810 00910C80FF6D psi requested boost BP2 70 05418670 4810 00910C80FF6D psi actual boost EPR 73 04410573 3010 0001000A0000 mBar exhaust pressure ICT 77 04410577 3008 00010001FFD8 ºC intercooler/charge air temperature ET1 78 05410678 3810 0001000AFFD8 ºC exhaust temp. before turbo ET2 78 05410678 4810 0001000AFFD8 ºC exhaust temp. before ox.cat. ET3 78 0321 2010 0001000AFFD8 ºC exhaust temp. before DPF ET4 78 0321 3010 0001000AFFD8 ºC exhaust temp. after DPF DPR 7A 0541067A 3810 0001000A0000 mBar DPF pressure drop available info on this car: PID contents 01 Monitor status since DTCs cleared 04 Calculated engine load value 05 Engine coolant temperature 0C Engine RPM 0D Vehicle speed 10 MAF air flow rate 13 Oxygen sensors present 1C OBD standards this vehicle conforms to 1F Run time since engine start 21 Distance traveled with malfunction indicator lamp (MIL) on 24 O2S1_WR_lambda(1): Equivalence Ratio Voltage 25 O2S2_WR_lambda(1): Equivalence Ratio Voltage 30 # of warm-ups since codes cleared 31 Distance traveled since codes cleared 33 Barometric pressure 3C Catalyst Temperature Bank 1, Sensor 1 41 Monitor status this drive cycle 42 Control module voltage 46 Ambient air temperature 49 Accelerator pedal position D 4A Accelerator pedal position E 4C Commanded throttle actuator 4F Maximum value for equivalence ratio, oxygen sensor voltage, oxygen sensor current, and intake manifold absolute pressure 5D Fuel injection timing 5E Engine fuel rate 61 Driver's demand engine - percent torque 62 Actual engine - percent torque 63 Engine reference torque 65 Auxiliary input / output supported 67 Engine coolant temperature 69 Commanded EGR and EGR Error 6D Fuel pressure control system 70 Boost pressure control 71 Variable Geometry turbo (VGT) control 73 Exhaust pressure 77 Charge air cooler temperature (CACT) 78 Exhaust Gas temperature (EGT) Bank 1 7A Diesel particulate filter (DPF) 7F Engine run time 81 Engine run time for Auxiliary Emissions Control Device(AECD)
Update 2013-4-11: 'Hotpocket correction' - divisor for PID 70 boost variable is 32, not 30; added average atmospheric subtraction for real boost; changed PID 7A wild guess to 'expected DPF pressure drop'
Update 2013-5-1: PID 70 and 6D: RXD 3810 is requested value, 4808 (8 bits only) is actual boost/fuel pressure, respectively; moved 6D into main part of table, after confirmation (by 'hotpocketdeath') that VCDS also indicates this PID is fuel pressure; changed interpretation for 73 and 7A
http://forums.tdiclub.com/showpost.php?p=4436770&postcount=362has anyone been able to convert the temperature readings to fahrenheit for the people in the US not accustomed to celsius?
Here is the data I am using for MAP actual and requested. Not quite sure what I've got wrong. Any help is appreciated.Still not getting correct readings for MAP actual and requested in torque. Every time I derive the formula from the hex code, I end up with a result in the 10000 ballpark for the equation with engine off or at idle. What should my equation, hex channel and variables be for this one?
Sent from my XT1080 using Tapatalk
Is it correct that that reports in Bar? Or is it mBar?Bassman, divide by 32, not multiply, for the manifold pressure numbers.
