pleopard
The EGT data is not reported on my 2010 Jetta sedan. Some with 2012s are reporting this works - same engine. Someone with a 2009 also reported this to work... Odd.
Doesn't work on my 2010 JSW. I've tried all four options in F, double checking them each time.The EGT data is not reported on my 2010 Jetta sedan. Some with 2012s are reporting this works - same engine. Someone with a 2009 also reported this to work... Odd.
I did the same thing with my 2010 Sportwagen!! Wouldn't work for me either! I sold the scann gauge II and bought the P3cars Digital Interface works beautifully!! cost a bit more but woth every dime IMHO!!Doesn't work on my 2010 JSW. I've tried all four options in F, double checking them each time.
It really doesn't make sense that it would work on older and newer, but not in between. I do have mine chipped so maybe that has something to do with it. I'll be talking to the chip people to see if they have any input, however I know when it was chipped and we were monitoring stats on the test drive after that we were able to watch EGT's with VCDS.
Really disappointed. My 'chip' is a stage 2 and I still have the DPF so I'd like to watch the EGT's, particularly once the weather starts to get warmer. I'm blowing water/meth so I'm interested in seeing what effect that has. So far none of the free software I've tried for my HEX-CAN generic dongle will pick up egts nor this hardware. Ugh.
Perhaps there is a bug in certain firmware revs of scangauge or the 2010's are using an address that deviates from the cansf standard.
Good find!I believe I've isolated the problem as I was able to pull temps with some generic PC software. The software I used, when connecting, see's two ECUs. They are listed as
- $7E8 CAN-ID ECU #1
- $7E9 CAN-ID ECU #2
When connecting to the first one, I can pull information from a bunch of different sensors. The second only allows some basics, like RPM, speed, etc.
When connected to the first, the EGT sensor is listed as:
78 - Exhaust Gas Temp (EGT) Bank 1 (EGT Bank 1 Sensor 1).
I'm going to relay this information to the folks at scangauge and see if they have any suggestions on how to force it to talk to the first address and not the second, which it appears to be defaulting to.
I'll keep everyone posted on what I find.
I assume so but I don't know what. This is probably best asked in a new thread or by sending a mail to support at scangauge.Are there any benefits or upgrades the SGII has over the 1st SG?? Looking to get one for the 12' JSW..Considered the OBDII Blutooth for the Torque App but getting rid of the droid 4 for the iPhone 5 real soon..
I actually spent 460.for this unit (which is now being discounted 100 less)I like the SC2 because it's a dedicated device, rather than tying up my phone, which I use for GPS and other things.
You should check in the Sportwagen forum.Will ScanGauge II be able to monitor boost pressure on 2011 JSW? I couldn't find on their website if it has digital gauge for MAP parameter.
Good to hear. I posted the standard OBD variable list as reported by my 2012 JSW TDI over here (are all 2010+ TDIs the same? ). Are you getting manifold/boost pressure (and other stuff not in that list) from your ECU-specific queries?Working with support to get them the raw hex responses from the query we got egt monitoring working. Ill post the configs later(working now)
Oopsies... Will do.You should check in the Sportwagen forum.![]()
Happy New Year! Any news on getting more PIDs into (or out of) the ScanGauge, hardtimes?Working with support to get them the raw hex responses from the query we got egt monitoring working. Ill post the configs later(working now)
It works decently. Ill be going to a p3cars unit when I can though. Just wish they had the displays in white on black like the rest of my mkvi read outs.Happy New Year! Any news on getting more PIDs into (or out of) the ScanGauge, hardtimes?
It is not necessary. Either way the response is from the same unit and will contain the same data.you had mentioned that addressing the ECU at 7E0 directly might be necessary
Just FYI: When I send a code '0178' using the 'cmds' feature on my old version 3.00 Scangauge, I get no reply. Naively I would have assumed that the Scangauge does use the default broadcast address 7DF for the 'cmds' feature.
Comp u:Someone asked how we have our scan gauge mounted, here are some pictures:
The wire runs between the dashboard and the windshield, around the tweeter, behind the cover for the fuse door, then pokes out right by the OBD port. No dangling wires
-J
Yes the trim between the tweeters is removed. It just pulls off. I also removed the trim covering the fusebox on the side of the dash.Comp u:
Did you have to remove the trim piece on top? Still not sure where the wires are running. Also, are you using the supplied velcro?
