hymato
I just got my scangaugeII , Can anyone help me with the dpf code, coolant temp and the boost codes for a 2010 jetta. I got the egt 1 pre turbo but I'm having problems getting the boost one to work.
our ecu's are the same....because the engines are the same. Doesn't matter what kinda of car you have if you have a CJAA engine, it will work.There should be instructions in the Jetta forum. This is the Passat forum.![]()
The engines are totally different. The Passat has a CKRA, not a CJAA.our ecu's are the same....because the engines are the same. Doesn't matter what kinda of car you have if you have a CJAA engine, it will work.
SC2 arrived today, set up went easy thanks to all of the posts in here.
I loaded EGT 1 and 3 plus the boost. Hopefully no more interrupted regents.
109 shipped from Advance auto was a smoking deal for what this thing will do.
A quick drive shows everything working.
Anyways, thanks to everyone here that figured out all the codes for the temps and boost!!!![]()
What is your refresh rate set to?sounds awesome, do you notice that its slow when reading boost, I mean like really slow...
Don't know I sent it back after comparing with the P3C...I just cant believe the difference when I had the 2, how fast can you set the refresh rate...What is your refresh rate set to?
I had to be on fast I'm sure I was and it still was slow for me, the P3C is right on...anywhoI think it has three speeds... slow, medium, and fast. When it's on fast, it updates several times per second, which is decent. On slow, it's useless for monitoring boost and EGT.
sweet, sounds like it works for what you need it for...I am out of town right now, but from the few trips I did with it, the response seemed fast. I know the EGT changes instantly. I don't have anything to compare the boost response to so it appears ok.
I am following the p3c thread you guys are on to see how they compare overall.
This SC2 is great for now, I can at least see true water temps, volts and mostly watch for regens.![]()
I know that the MFD on my car over-reports by 1.5 to 2 mpg, but scangauge mpg seems to report much lower....I have engine set to diesel a....
is this right, or does it need tweaking?
Hi guys, so I need help here. I got my scangauge quite some time ago, and I just set it for re-gen monitoring or at least I THOUGHT I did. and I can't remember which one I set it up for. I was messaging with tdiatlast and he recommended monitoring the EGR temp, which I think is above named EG1? But since I'm not sure can someone just state the obvious for me and tell me which one is for the EGR temp and which one do I need for monitoring re-gens. I may have coded mine incorrectly when I first got it and may have been watching the wrong paramter for re-gens. lol. Thanks in advance! btw, i just trolled thru this whole thread to refresh my memory but it didnt help at all just confused me more. lolEGT 1 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EG1
EGT 2 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 054106780000
RXD: 4808
MTH: 09000032FFD8
NAM: EG2
EGT 3 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 032100000000
RXD: 2010
MTH: 00090032FFD8
NAM: EG3
EGT 4 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 032100000000
RXD: 3010
MTH: 00090032FFD8
NAM: EG4
EGT1 is correct, I also monitor turbo boost for active regens. EGT temp will drop but regens are still active as noted by elevated turbo boost at idle.Hi guys, so I need help here. I got my scangauge quite some time ago, and I just set it for re-gen monitoring or at least I THOUGHT I did. and I can't remember which one I set it up for. I was messaging with tdiatlast and he recommended monitoring the EGR temp, which I think is above named EG1? But since I'm not sure can someone just state the obvious for me and tell me which one is for the EGR temp and which one do I need for monitoring re-gens. I may have coded mine incorrectly when I first got it and may have been watching the wrong paramter for re-gens. lol. Thanks in advance! btw, i just trolled thru this whole thread to refresh my memory but it didnt help at all just confused me more. lol
Thanks so much VeeDub!This is the most useful EGT sensor to monitor if you are only interested in regens. Anything over 1000 steady is a regen...
I monitor two sensors... the one listed above and the pre-turbo sensor that is "EG1"
Thanks darrelld! I'm going to add this parameter as well!EGT1 is correct, I also monitor turbo boost for active regens. EGT temp will drop but regens are still active as noted by elevated turbo boost at idle.
TXD - 07DF0170
RXF - 054186700000
RXD - 3810
MTH - 00910BB8FF64
NAM - PSI
Hi TurboDiesel, for me its more to idiot proof interrupting re-gens. I don't want to have to listen for fan speed (although fan speed is a good indication), or watch for a slight higher than idle rpm. Maybe its the a/c compressor kickin in that is the cause for a slightly higher idle, if the a/c happens to be on. I just like to have all possible data available for me to see and interpret than to just go off of physical things happening. but if you're that keen to a re-gen w/o a scan gauge, i think thats awesome! but im just an idiot who is very lazy! lol!No offense to anyone with a Scan Gauge (I think they are pretty awesome but don't want one on my dash distracting me.) but honestly, I don't understand how people aren't noticing regens even without a Scan Gauge. In my car, its pretty obvious. My car very periodically regens (about every 300-400 miles, as is to be expected) and when it does so, the idle RPM goes up to around 900 as opposed to the normal 780 or so, in conjunction with the fans going from silent to hurricane force in no time. Instant MPG suffers, and I can hear the engine become ever so slightly more "diesel" sounding with the extra injection event.
I haven't (and don't plan to) ever shut it off in a regen, though I have already experienced quite a few with 2200k miles on the clock. I simply continue to drive it while it is still obviously regenerating, and then as soon as the idle drops again and the fans spin down to the usual speed, I continue to drive for a few more minutes with ample coasting in gear to help cool down that turbo and exhaust system ASAP. Done.
Is my procedure necessary? No. Does it make me feel like I'm saving my turbo, avoiding DPF clogging, and minimizing oil dilution with fuel? Absolutely.
Here is the best information to monitor on your Passat...Personally want to monitor REGENS, OK back to the topic....
Just got a SGII. Installed and got it up & running today w/ custom XGAUGES thanks to this thread.
From this thread: EGT1 and Boost worked. The factory Water Temp worked, with those three
displayed, I saw a REGEN first drive out. The EGT1 spiked to 1200F and water temp went up
a few degrees. It did not last long..... The LOD factory gauge worked. I assume that is torque.
I recall monitoring torque with my ROSS TECH CAN cable and saving it to file; the % was about
the same on freeway as I saw with SGII.
From this thread, could NOT get Catalytic Converter to work, so I went with "EGT4)
"Catalyst Temperature" from Scangauge II site (did not work):
TXD: 07DF013C
RXF: 0441053C0000
RXD: 2810
MTH: 00090032FFD8
I went with EGT4 and it worked. This is just past DPF I read.
TXD: 07DF0178
RXF: 032100000000
RXD: 3010
MTH: 00090032FFD8
Is "EGT3" better to monitor? I think one EGT is all you need for REGEN monitoring?
Any comments on good XGAUGES to add? Thanks.
Thanks, but the code for CAT you posted is the same one I used. It did not work for me.... I might have had a typo.... I'll try it again.Here is the best information to monitor on your Passat...
CAT B1S1: This is useful for monitoring regeneration activity. Anything over 1000F is a regen.
TXD: 07DF013C
RXF: 0441053C0000
RXD: 2810
MTH: 00090032FFD8
NAM: CAT
Personal note: I watch both exhaust temp sensors listed above and wait for both to be below 450F before shutting off the engine.
