Scan Gauge II XGauge - EGT & Boost
Livefreeordie89
NH
2014 Jetta
Can any guru take
TXD is 07DF01+PID
name PID RXF RXD MTH units comment
ICT 77 04410577 3008 0001000AFFD8 ºC intercooler/charge air temperature
and convert to *F?
Diesl
Chicago
'78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
Apparently I made a mistake with the 'A' in the math, it should be a '1' (no division by ten). So, putting what kapps and savageman posted together, the MTH should be 00090005FFD8 for Fahrenheit.
But why not stick to good ol' metric ºC, as the car's engineers surely intended, instead of converting to a scale invented by some obscure hanseatic physicist for use in his hometown Danzig?:D
Livefreeordie89
NH
2014 Jetta
Oh I wont disagree with you there, As a mechanical engineer I agree just with water temp in F it would be a mind F*** to see *C intake air and *F water temp
Livefreeordie89
NH
2014 Jetta
We know *F=*C *9/5 + 32
I see the 9 and the 5 in the MTH which im guessing is the 9/5 but where is the plus 32? is it the FFD8?
Diesl
Chicago
There's a 40 degrees offset in those temperature definitions (probably so it never has to go negative), which is what the FFD8 takes care of. And -40ºC=-40ºF. Nifty, eh?
coers
peoria,il
2012 VW JETTA TDI, BLACK EXTERIOR AND INTERIOR AND 6SPD MANUAL
So I am really thinking about getting one of these for my car. Im still in limbo if I should get the Scan Gauge II or the Ultra Gauge. Im leaning towards the ultra gauge cause it's much cheaper and seems to monitor everything I am looking for. But it seems all of you are using the Scan Gauge II so is anyone currently using the Ultra Gauge or have use both?
Paulinski
Brantford, Ontaro
09 Jetta Wagon Highline
thanks diesl i put in the boost and egt1 from your list i believe its working good..idle is .3 or so boost and max was 23.1 ish....egts are 120-180 idling (3 inch sure cools quick) .... WOT pulls i was seeing 600s
I don't think your gauge is displaying the EGT correctly.
I have the same set up as you. Malone / Rawtek and I'm ideling at 320 - coasting in gear at 160 - 180.
Your WOT ETG's are also really low...Any stomp on mine and the numbers for north of 1100 in a hurry....
Livefreeordie89
NH
2014 Jetta
The time old problem of units....One of you are in *C one of you are in *F
Rmohd
Illinois city Illinois
2012 Passat
I have an ultra gauge and now the scan gauge II, what I can say is this at twice the price it is twice the device,,,my scan gauge is in my scion and is a great gauge for simple gauges and normal temp, volt, fuel and so on, it has no programmable features, what your car has is what you can get, so my 2 cents is if you have a gasser and want more details may be fine. For the Diesel I wanted EGT and Boost, the scan gauge delivered,, Thanks to the fine folks here, I entered the codes provided in the 1st post for the Passat and was running with monitors working in 30 min, still need to dial in the permanent mount but that will wait till the weekend. picked it up at auto zone,, I mentioned the $10 off that you can get online and they gave it to me in the store........
thanks to all on this post and form as the help and information here is priceless,,, now I have my sites set on the Ross tech cable and software.....
Loki
SE Wisconsin
2005 NB TDI; 2006 Golf TDI
Anyone know if the scan gauge can display oil temp. I have water temp and suspect during warm up that oil temp follows water temp. In light of the many turbo failures, I would like to watch oil temp during cold weather starts, because the turbo might not be getting enough oil until it warms up a bit.
La Conner, WA
The Passat TDI doesn't have an oil temperature sensor. It may be possible to retrofit the one from a Beetle TDI.
Salsaman06
Texas
2013 Passat TDI SEL (sold back to VWoA Dec 21, 2016)
Ditto what rmohd said. I started with an UltraGuage too but then switched to a ScanGuage when I discovered it couldnt display EGT and Boost. (I bought the UG before the EGT and BST programmatics were known for the SG)
Have a OBD II bluetooth module on the way and plan to use Torque on a Galaxy Tab 3 7.0. Torque is even more versatile but the display device and mounting options are a bit more complex.
Moosenuckle
Pittsburgh ,Pa
03 tdi ,Mk2 aba swap w/charger; 97 Dodge cummins 5spd
Guys kinda of a Noob when it comes to this gauge. i got the SG II for my 03 jetta TDI. i was wondering will the Xgauge coding work for my car to get the EGT and boost readings? i see you guys can in 2010 and newer can. so is this possible for me? if so i can use the same codes?:confused:
La Conner, WA
03 Jetta is going to be very different. For starters, it doesn't have an EGT sensor, so you won't be able to monitor that.
Vince Waldon
Edmonton AB Canada
...but if you search on "boost xgauge" in the A4 forum specifically you should be able to find a bunch of threads discussing the appropriate coding for your A4 (1995.5-2003).
Moosenuckle
Pittsburgh ,Pa
Yea that's what i kinda figured there was no EGT sensor :mad: however i am able to monitor boost right? here is what I'm monitoring now Volts, WT,MPG, and IA deg.. Is there anything i can monitor in the x-gauge section..
zdg13
Hershey, PA
2010 Jetta 2.0 TDI 6 Spd Man
Alright guys I was wondering something, I have a 2010 Jetta 2.0CR and Tomo366 was having problems because the Scangauge II didn't want to read his EGTs. Has anyone fixed this problem or know of another monitor that does read EGTs along with other engine monitors?
Livefreeordie89
NH
2014 Jetta
EGT 1 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EG1
EGT 2 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 054106780000
RXD: 4808
MTH: 09000032FFD8
NAM: EG2
EGT 3 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 032100000000
RXD: 2010
MTH: 00090032FFD8
NAM: EG3
EGT 4 (Degrees Fahrenheit)
TXD: 07DF0178
RXF: 032100000000
RXD: 3010
MTH: 00090032FFD8
NAM: EG4
Boost (PSI)
TXD - 07DF0170
RXF - 054186700000
RXD - 3810
MTH - 00910BB8FF64
NAM - PSI
AreaMan
Cincinnati, OH
2013 Passat 6M
Sorry if I'm being dense here, but I'm a bit confused...
I see EGT settings from the Jetta guys that work for me and other 2012-2014 Passat owners. On post 1 and some other places, I see other Passat owners using the CANSF Catalyst settings from the ScanGauge site. I tried both, and get different readings for "EGT1".
So...for a 2013 Passat, which one should I be using: The CANSF setting from post 1 or the settings in post 142?:confused:
carlrx7
Charleston, SC
2013 Passat SEL TDI
Picked up a SGII using the $50 coupon, sent a video to my father and now he is getting one for his 56th Birthday to use on his F250 PSD.
BTW, Does anyone notice a slow flickering (low screen refresh) when it is in LOW Backlight?
Is this normal or return worthy?
Thanks!
-Carl
AreaMan
Cincinnati, OH
2013 Passat 6M
2012-2014 Passat TDI
Pre-turbo EGT, the one we care about...
Is it:
Choice "A" (from "self study guide"):
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
...or...
Choice "B" (From Scangauge site CANSF):
TXID: 07DF013C
RXF: 0441053C0000
RXD: 2810
MTH: 00090032FFD8
Can a fellow TDI'er set me straight?:)
La Conner, WA
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EG1
That is the pre-turbo sensor. You can change "NAM" to be whatever three letter acronym you want. I use "EGT" for pre-turbo and "CAT" for pre-cat. I monitor both on ScanGauge.
carlrx7
Charleston, SC
2013 Passat SEL TDI
I'll try reseating the obdii
will report back on other colors.
Thanks!
No deal on reseating connector.
I increased the refresh rate now it is pulsing faster.
Low brightness it does it in every color EXCEPT Red.
High brightness it is fine EXCEPT for RED. weird..
going to give it another week and then look up the return policy from advance.
-Carl
La Conner, WA
Definitely doesn't sound normal unless your eye are more sensitive to flickering than mine. I would go ahead and exchange it.
AreaMan
Cincinnati, OH
2013 Passat 6M
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EG1
Thanks VeeDubTDI :cool:
BPofMD
Maryland
2012 Passat SE
The people at Scan Gauge are really great to work with.... send them an email or phone them.... they will impress you.
