Frankendiesel
Starting problem - had similar symptom on my Frankendiesel. Mine was fuel line issues though (it's been a year now, I don't remember exactly what the issue was!) You may want to find out if your fuel pump is posing a restriction to the return line. Are you running the electric in-tank pump all the time? Some of them will restrict the fuel flow if they're not running, so I've heard. I don't run mine all the time either. Otherwise, I agree with the VCDS recommendation. Did you do a timing belt when you had the engine out? I did mine and still need to time it!
Speaking of the electric fuel pump, a friend of mine (we both work for an avionics company) reminded me of a jet airliner that blew up in flight becuase the electric in-tank fuel pump ignited the vapors in the mostly-empty fuel cell. I try not to run my pump at all. It may come down to needing to remove it completely.
Oh - one more thing...did you remove/bypass all the gasoline legacy equipment in the fuel lines, i.e. fuel vapor canister, etc.?
It is a great feeling to drive the conversion for the first time, doesn't it!
Allow me to officially welcome you to the club!
TLG
TLG
