Finally some long-overdue visual updates. As you can see, I cut up the SAAB intercooler and made it one long one to fit the Saturn; being a 15-tube intercooler, it looks a little lopsided, but the eight tubes feed into the seven tubes as it did in the SAAB. I made a small shelf that bolts into some existing holes in the Saturn radiator to support it, and will make a couple of brackets to bolt it to the origional A/C condenser holes in the radiator. I bent up some stainless steel fuel lines to route them over to the drivers side where the Saturn fuel lines run, just need to finish making some brackets to bolt it to the TDI, picking up some existing mounting points.
I spaced the Saturn fan foward about 3/8" to clear the oil filter; it's a bit tight, maybe an 1/8" or so, I'll have to see if I can move it forward a bit more. I bought a Super Tech ST8 (same as a Fram PH8) to try...I can get it on and off ok, just would like a little more room in there as I'm not sure yet how much room I'll have when the motor is running.
The shifter is one of those "wish I'd figured this out before" projects, when I discovered that the TDI shifter had the same forward hole spacing as the Saturn shifter, just needed a couple of 5/8" CRS stand-offs to bolt it in. I reamed the extra holes in the TDI shifter base and moved the studs around, then made an .090" aluminum bridge to support the shifter front-to-rear, and a couple of 5/8" aluminum blocks to mate the bridge to the Saturn rear shifter mounting points. It centers perfectly in the console, and functions better than the Saturn shifter I reworked. I raised the pivot point by 3/4" to shorten the throw, just need to put the console back in and measure how much I can cut the shaft down. I'll probably thread this for the shift knob, haven't figured out yet what I will use.
