ryanp
- Joined
- Jun 22, 2008
- Location
- Barnsley, South Yorkshire, UK
- TDI
- Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
I am based in the UK and have contacts throughout Europe so I can get hold of the best Euro parts at the best prices!
Here is a small selection of what I can get.
All prices quoted are in £ / GBP / British Pound and INCLUDE DHL EXPRESS SHIPPING to the USA and Canada. For estimated conversion rates, please check http://www.xe.com/.
Intakes
All of these intakes will bolt up to all PD and VE heads with the same gasket as the stock intake. They will also fit the AAZ TD if you are an IDI guy!
PD150 Intakes
PD150 Intake manifold (Bare) - £140 Much better than the stock ALH intake and wont kill your engine like the US PD intakes do when they ingest the butterflies.
Complete PD150 Intake with EGR and Elbow Pipe - £175
Can also be supplied with EGR Cooler for £10 Extra
Passat RHS / Driver side PD Intake
Passat RHS PD intakes (Bare) - £140 These are required if you want a clean install for a FMIC to cut down on excessive pipework.
SDI ‘Snail’ Intake
These are the best inlet I’ve come across so far, the runners are over a foot long and it has a large plenum and fits in a very compact space.
With Genuine VW 'RacePipe' (2.5"), Genuine VW EGR Blank and Plugged Breather Hole. READY TO FIT - £175
PD150 TIP Kit’s
They come complete with everything you need to fit them - £140
For an extra £70 when purchased with a TIP Kit I can supply a R32 DSG Snorkel Kit (a small mod to the Air box bottom is needed for the MUCH larger snorkel)
If you want a complete OEM setup the R32 air box kit (including new filter element, the Air box Bottom is NOT available on itself) can be purchased for an extra £100 on top of the snorkle price - The R32 Airbox and Snorkle are £170 combined
This will need to be used with a R32 MAF housing, the PD150 accordion hose will slip over the MAF with a little persuasion to make the largest OEM Intake setup. I can supply a new R32 DSG MAF sensor for £125
If you already purchased a TIP kit shipping will be £50 for the above 2 items together due to the size of the box!
PD150 GT1749VB Turbo Also known as the VNT-17
New - £700 Shipped
Used - £475 Shipped
VNT-17s are shipped with either the Red Outlet Pipe or Modified to fit the ALH / BEW Directly (welded outlet)
cont...
Intakes
PD150 Intakes
SDI ‘Snail’ Intake
PD150 TIP Kit’s
New - £700 Shipped
Used - £475 Shipped
cont...
