Powder Hound
- Joined
- Oct 25, 1999
- Location
- Under a Bridge, Crestview, FL, USA
- TDI
- '00 Golf 4dr White 5sp, '02 Jettachero 5sp, Wife's '03 NB Platinum Gray auto(!)
Hi Everyone,
I have a wheel rusted to a rear hub on my new-to-me 2003 Jetta. It appears that multiple winters of salt induced corrosion have done their damage and corrosion-welded the aluminum wheel (Long Beach, if you are curious) to the brake hub.
I've tried multiple applications of PB blaster, but it is hard to get the spray to the outside circumference through the wheel spokes. Spraying the inner area and in the lug bolt holes has been done multiple times.
I have tried rolling the car around with loosened lug bolts after PB Blaster. That worked on the other side, but this one is still solid.
What are your favorite tricks for loosening a wheel rusted to the brake rotor? I'm not interested in destroying the hub. Yet.
Cheers,
PH
Cheers,
PH
